Results 1 to 9 of 9
Thread: Battery Connector
    Feb 2006
    Rosemount, MN
    Battery Connector
    Wondering if someone might have a suggestion where I could get one of these?
    It's from my wife's 2013 Ford Explorer. I purchased a new battery and I cannot get this old one off.
    Ford wants $285 for this and the cable.
    I bought a cheap one from O'Reilley's, but the bolt that the cable connects to is too big.
    Feb 2017
    Tampa, FL
    you can drill out the hole on the cable terminal to fit the bolt
    Feb 2017
    Tampa, FL
    or you can just get the factory one off of the old battery...
    or the junkyard,
    or strip the wire and clamp the new terminal onto the wire (if its that kind of terminal)
    follow your heart
    Stick a screwdriver in the split an twist the screwdriver. Grab the terminal with some pliers and twist off.
    Mix up some baking soda and water into a paste and coat the terminal with it. After it stops foaming rinse with water.
    Jul 2014
    Castine, Maine & Brooklyn, NY & Walton, NY
    Soak with PB Blaster for a day if no rush or 5 minutes and wack the terminal with a small ball peen hammer. I love heating the metal but I can't say how with a battery-no spark or open flames.
    Feb 2006
    Rosemount, MN
    Searched online and found Ford part# BT4Z-14450-BA and a Ford dealer about 40 minutes from my house had one for about $20. Thanks for the help.
    Jun 2017
    Texas
    Backup clamp: Taurus / Ford 500 / Mercury Montego
    I just spent last night f___ - uh, I mean, 'messing' with a battery clamp from an '06 Montego (Ford Five Hundred, later renamed the Taurus), trying to get all the corrosion off. Getting ready for the cold weather...
    The Montego clamp is a virtual duplicate of the clamp pictured, and they are still making the Taurus body style.
    The comments in this thread are right on. Nothing better than baking soda for the green / blue stuff.
    I will say that the baking soda works best when you have gotten the crap off by mechanical means first; wire brush and screwdriver-as-chisel. The soda is best at getting the last little bit bubbled away. If you try to get the whole glob of green / blue stuff with just baking soda, you will be there a while.
    Keith in Houston
    Rookie, '04 DTR
    Oct 2008
    Toronto, ON
    I pour hot water from my kettle onto the battery terminal to get rid of the blue stuff. Works instantly and is completely touchless.
  1. Wanted To Buy Need the fog light connector!!!
    By BlkMamba24 in forum Marauder Parts/Misc. Wanted
    Last Post: 07-27-2012, 11:13 AM
  2. New Battery and Alternator - Battery Light Still On
    Last Post: 06-21-2010, 10:07 AM
  3. Clock Connector
    By fastblackmerc in forum Marauder Parts/Misc. Wanted
    Last Post: 11-03-2008, 07:29 AM
  4. Optima Battery anyone? And OEM battery questions
    By Breadfan in forum Shop Talk
    Last Post: 05-30-2006, 08:38 AM
  5. Oil on MAF Connector
    By hbarrett in forum Shop Talk
    Last Post: 07-05-2005, 10:35 AM
