Results 1 to 15 of 18
Thread: Oil housing gasket
    Dec 2010
    Topeka, Ks
    Oil housing gasket
    How big of a job is it to change a leaky oil housing gasket on the '04? What are the steps? Thanks in advance.
    BW
    Marauders x 3
    Drain oil
    Drain radiator
    Make a mess draining thermostat housing. install new oem t-stat
    Pull 4 bolts holding the housing make a even bigger mess, if you have some swivel extensions, this makes life a little easier.
    Inspect housing for cracks.
    Clean gasket off housing, fill holes where the gasket was at on the housing, the housing tends to corrode, i just use some right stuff while installing the gasket.
    Clean surfaces, install new gasket with sealer. New oil, oil filter, coolant.
    Then fill with coolant and make sure heater core has plenty of coolant in it.
    It makes a really big mess, but if you have a trash can lid sized catch all, then it helps.
    Other than a mess, really easy job. 4 bolts
    make sure cooling system is burped for air, there are instructions on how to or it will overheat
    Feb 2017
    Chicago, Illinois
    You do not have to replace or remove the thermostat to remove the housing and then the gasket. You will also have to remove the “sending unit” to get access to the left lower bolt. Don’t over tighten then plastic drain plug on the radiator. Also make sure your cross over plug isn’t seized, if so torch that sucker. +1 on the right stuff, it seals the imperfections on the housing unit and you could put it on the gasket if you want overkill.
    Oct 2004
    MO
    deleted. .lost link
    ncmm
    '04 Silver Birch MM 300A, build date:03/11/04, bought new 10/04 traded 8/08, 27k miles,
    '04 Silver Birch MM 300A, build date:12/23/03, bought used 3/16/12, 24k miles
    113k miles as of 8/21/19. . .
    update. . . sold 11/5/2019, 116k miles
    Visit My Old Gallery
    Quote Originally Posted by NorthShoreChiMM View Post
    You don't have to pull the sending unit, just use wobble extensions and socket
    Thermostat was advised for maintenance, 13 year old part, coolant system is open, it should be replaced.
    We forgot to mention buying a new COT tube oring on the plug
    Oil housing gasket
    Disregard, figured it out, thanks.
    Found Byron’s instruction, all good, but going to have to reuse the COT plug o-ring as those puppies are hard to find.
    Quote Originally Posted by Svashtar View Post
    Somehow the o-ring to my COT cap disappeared. It wasn’t there when I took the cap off. Does anyone have an extra they can send me from the 10-packs amazon used to sell? I’ll gladly send you $ for shipping and a few beers.
    I found them online and for 6 of them they are charging $5 for materials and $25 for UPS ground shipping. ??? I figure 6 weigh a fraction of an ounce maybe.
    It hasn’t been leaking so I don’t know how critical this is, but figure I better have it. Thanks for your help.
    Researching SVTPerformance and this comes up.
    http://www.oringsandmore.com/viton-o...ice-for-5-pcs/
    Oil housing gasket
    Thanks Bob, I’ll take a look. These are -14 though and Bryan’s original link was for -15, so I’ll see if they have that size. Appreciate the link.
    I got the COT out pretty easily to finally change the O-rings and am cleaning that up and changing the OF housing gasket as well. The four bolts are almost impossible to see though. I see two on top but they’re angled down so might be for something else. I’ll figure it out.
    P.S. Spent 10 minutes under the car in the sun today wiping stuff down and couldn’t see a thing around the housing. Went out tonight with a flashlight and the bolts are obvious. No problem getting around the sending unit with a wobbly.
    Oil housing gasket
    Ok, dumb question: Does the COT cap o-ring go up against the top underside of the cap above the threads, or is it the O-ring in the groove in the center of the cap? My cap was on tight with no leaking, but I swear there used to be a second o-ring on top of the threads. Thanks again.
    Sorry, I misread and thought you were looking for the crossover tube Orings..
    The plug is - AS 568-015
    Post 19
    https://www.svtperformance.com/threa...-rings.748060/
    There is only the one Oring on the plug that I recall.
    Post 19
    Thanks Bob. The link to the crossover tube o-rings is also helpful because of the price. I can’t recall where I got these 4 now, but I paid at least $20 for them. (I have to start bookmarking everything because the search here sucks.)
    The COT plug seems to have a space above the threads and under the cap for an o-ring, but one wasn’t there, just the center one. Since it isn’t leaking I won’t worry about it.
    I don’t know how you find these links so quick but appreciate it.
    I should have some cot plug o rings here. Gotta find em
    Drain oil
    Drain radiator
    Thanks for all this Bryan. I got the housing off (that last bolt behind the sending unit was the messy one!) and there is some slight corrosion on the removable side of the housing where the gasket was. I sanded it out on a piece of plate glass covered with high grit sandpaper, but it’s a lot harder to smooth out the block side.
    I have some sticky permatex form-a-gasket I’ll coat both sides with and hope that works to tighten things up.
    I’m not sure exactly how tight they were, but I had to lean on all 4 bolts pretty hard to break them free; I’m guessing they were on at about 50-60 ft lbs.
  1. Replacing Oil Filter Housing Gasket
    By NorthShoreChiMM in forum Shop Talk
    Last Post: 12-20-2017, 09:10 AM
  2. Oil Filter Housing Gasket
    Last Post: 12-03-2017, 12:51 AM
  3. What is this gasket used for?
    By NYGarageQueen in forum Exhaust
    Last Post: 05-02-2010, 06:42 PM
  4. Need gasket
    By 2ndMDRebel in forum Kook's Custom Headers
    Last Post: 04-30-2006, 10:07 PM
  5. Pan Gasket
    By TheDonk in forum Transmissions
    Last Post: 04-02-2006, 06:10 PM
