Changing oil today and found hose twice it normal size . Ford no longer makes them and the aftermarket ones are 1/4 inch too small . Anyone have a good oem lower hose from engine to thermostat ? It’s the short one about 7 inches long.
03 black mm stock, daily driver
04 silver mm Easton swap, 4.10, full SW exhaust, and more. 428 rwhp ,419 rwtq tuned by MO's
Take it to your local FLAPS and see if there is one similar or that can be cut out from a longer hose.
You can cut the section that’s bad off the tee fitting quite easily and replace it with a match up trimmed to fit like already mentioned. Just use a clamp when mating the new one to the tee. You could do all three and just reuse the tee if you really wanted.
That’s what I did for my radiator and coolant tank side when I replaced both of them with custom ones.
I think a number of members, including myself had the same issue a little while back:
https://www.mercurymarauder.net/foru...d.php?t=103012
Found a hose that should work. Cut to fit. Thank u for the help.
Let us know where you found it...part number...anything else to help.
Hose is a Gates 20687 for O’Reilly auto parts.
Cool...thanks!
That looks pretty close. It looks like you’ll be separating one section then?
