Page 4 of 4 FirstFirst 1234
Results 46 to 58 of 58
Thread: EATC Blend Door Actuator
  1. #46
    Sep 2005
    APPLE VALLEY,CA
    Currently, my floor and defrost are blowing out the vents. The heat will only come on when the engine is fully warmed otherwise it is cold.
    My A/C is also working properly.
    My 04 is 16 years old. I replaced the Blend Door Actuator in it about 8 years ago.
    The WORST part Ford Makes. Plastic gears break. My '97 Continental needed it twice, and I replaced my MKS's for a second time last year. (The MKS has 3 blend door actuators. The one that needed replacing twice was right behind the glove box.)
  2. #47
    Run the EATC self-test. let us know what codes you receive.
  3. #48
    Sep 2005
    APPLE VALLEY,CA
    Can you remind me how to do it?
  4. #49
    Nov 2012
    Sacramento
    Cali Marauders, I have same issue. Maybe we can get together and do all three!
  5. #50
    https://www.mercurymarauder.net/foru...-HVAC-PROBLEMS
  6. #51
    Sep 2005
    APPLE VALLEY,CA
    Thanks for the link again.
  7. #52
    Nov 2012
    Sacramento
    Have same issue. Air through correct vents, but all cold all the time (not hot). Searched MN.net (thank you all), CV.net, and UTube.
    Ran the EATC test and popped code 24 or 024 = Blend Door.
    Had read somewhere to adjust temp to different numbers (most drivers have a cold number and a hot number they use predominantly), and near end of EATC test to "jostle" the blend door unit. I adjusted my temp from 90 down to 75, and ran the test again.
    As it went through its "test" I jostled the dash and unit and it adjusted! 75 degree Air now through defrost. Notes then said to unplug unit ? when at desired temp, to keep it set there until unit can be replaced.
    I stopped while I was ahead (as it was getting dark), as I can now defrost windshield AND not cook at 90 all day everyday. Will see about unplugging unit today.
    Still need to change out unit. Ordered new OEM part today $48 shipped.
    Hope this helps a little... real time share of data found online, and actual first had application result.
  8. #53
    Most of the time running the self-test multiple times will "reset" the actuator. It will continue to work for a time.
  9. #54
    Dec 2020
    Los Angeles California
    What tools are needed for this job?
  10. #55
    Quote Originally Posted by Pantera View Post
    Small offset ratchet and 5/16 socket for the actuator. More if your going to take the dash part of the way out.
  11. #56
    Jan 2013
    Port Credit, Ontario, Canada
    I just graduated! On blend door Wasn’t that bad at all, after I thought “why didn’t I do this a year ago?”
  12. #57
    Dec 2021
    Cape Coral, Fl
    I'm wondering, with all the ingenuity here, why doesn't someone make and sell a replacement gear for the actuator made of brass or aluminum?
    Sent from somewhere near my Marauder using Tapatalk
  13. #58
    The cost of the gear would outweigh the cost of a new actuator.
  1. blend door actuator
    By Chayton in forum Shop Talk
    Last Post: 04-13-2017, 12:00 PM
  2. blend door actuator
    By MMARAUDER in forum Shop Talk
    Last Post: 04-07-2014, 04:27 PM
  3. Blend door actuator
    By BLACKMARAUDER04 in forum Shop Talk
    Last Post: 05-26-2013, 09:17 PM
  4. Blend Door Actuator
    By kmastl in forum Shop Talk
    Last Post: 08-27-2012, 10:17 AM
  5. Replacing Blend door actuator
    By Flynlow in forum Shop Talk
    Last Post: 07-17-2011, 06:50 PM
