Results 1 to 15 of 16
Thread: ABS, brake lites illuminated.
    Bossier City, La
    Question ABS, brake lites illuminated.
    Question: can worn brake pads cause the ABS/brake warning lites to come on?
    cleared after recycling system.
    Wisconsin
    Quote Originally Posted by Pat View Post
    Worn pads can trigger brake light for low fluid but ABS light, No.
    Abs is all about sensor/tone ring relation.
    Check all your sensors to see if one loosened up and moved away from tone ring.
    wheel bearing (front) failure can also trigger ABS light.
    If no visible issues, get the code read. Sensor or module may have puked.
    Can't tell until code is known.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    The Marauder's rear ABS sensor has been known to come loose.
    ďWhen you canít make them see the light, make them feel the heat.Ē
    ďBe polite, be professional, but have a plan to kill everybody you meet.Ē
    Charlotte, N.C.
    Right on Mr. Fix it!!--
    -mine was blinking light and took off rear wheel and --checked and bolt holding it had loosen and fallen out and even the magnet to hold the darn thing had separated --thus the steady light----duh! this was awhile back (years) and provided yet another item to file away about his vehicle to keep in memory for future ,,,,,and of course check the blinking light sooner ...after all that's what they are for.....LOL
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
    Pat, if the brake pads were worn down sufficiently to cause the fluid level in the MC to drop to the MIN line, the brake light could illuminate, but that wouldn't affect the ABS. If it cleared, then it may have been "just one of those things", but if it comes back, get the codes read. Also, if you have a Windows laptop, FORScan will run a self-test on the ABS and display any codes it finds. The best part is it's free.
    https://forscan.org/download.html
    same problem, but intermittent & NO CODES
    2004MM, 160K
    ABS & Brake lights off on cold start, but usually both come on after auto warms up. Sometimes - rarely - they go off again. Also - rarely - they turn off after slowly going over rough dirt road, pitching & rocking. Again, intermittent, but damned annoying. Now 'On' more than 'Off'.
    My indy shop very Ford-oriented, and have done all service ex-warranty.
    Mechanic checked for codes twice with ABS & Brake panel lights both on and off - no codes at all. Checked/topped off brake fluid reservoir. Moved float to make sure it wasn't stuck. Unplugged connector and cleaned contacts on both sides.
    Showed him printout of this thread. Thought tone wheel/magnet problem should really show code. Car just had complete spring service; no front bearing problems noted. (They did replace RR axle & bearings 2-3 years ago.)
    Any suggestions? Would really appreciate some help!
    BTW, can fluid reservoir with float & connector be replaced without replacing entire master cyl. assembly, or is it all one $$$ part?
    Jul 2010
    Guntersville Al.
    Quote Originally Posted by Chachacharlie View Post
    2004MM, 160K
    This is my exact problem also. I've had it looked at twice with the same results. The scanner would read either "No Codes" or "No communication". The only thought I had was the ABS unit that mounts to the frame was bad or going bad. I'm watching this thread. Somebody's has the answer to this.
    It was an honor to have
    my ASS kicked by you!
    Rest In Peace!
    Paul T. Casey
    Jun 2007
    Whitehall, PA
    Quote Originally Posted by Granddaddy Marq View Post
    That’s what happened, the electronic part on the front of it could be unbolted and sent out and repaired, I sent one out to these people and had it repaired for $100. https://www.shop.modulerepairpro.com/Marauder_c36.htm
    2003 DBP/LF - # 36 sold
    2003 DBP/LF - # 205 sold
    2004 Black - Trilogy #43
    2003 Black - sold
    2004 DTR - sold
    Jul 2010
    Guntersville Al.
    Thatís what happened, the electronic part on the front of it could be unbolted and sent out and repaired, I sent one out to these people and had it repaired for $100. https://www.shop.modulerepairpro.com/Marauder_c36.htm
    Derek, You are the man! I just so happen to have an extra one of those. Your on the sauce and nuts list now.
    Rest In Peace!
    Paul T. Casey
    Just to be clear - this module can fail and still not throw any codes at all?
    And after replacement, it cures this problem with its specific symptoms?
    Module Repair Pro Inc. says car can be driven without module. Other than lack of ABS, ANY other concerns?
    Jun 2007
    Whitehall, PA
    Typically when it fails you get the ABS light and the brake light in the instrument cluster. It probably wonít throw any codes because most of the time when it fails you canít connect through the OBDii port.
    2003 Black - sold
    2004 DTR - sold
    Lehigh Valley, PA
    The module on my friends 04 sport died and when connecting to the car with forscan, forscan couldn't even find the ABS module. The ABS module wasn't showing codes because the ABS module wasn't even powering on.
    2063/3214
    5377/7838
    You can, but I wouldn't.... It will become obvious when you take the module off as to why some would advise not to drive it.
    When you are dead, you donít know you are dead. It is difficult only for others. It is the same way when you are stupid.
    Trilogy # 192 / T.S. 0012
    Feb 2017
    New Orleans, LA
    ive driven mine with the abs module disabled and not any issues?
    Sep 2010
    Western WA
    On my son's 02 Grand Marquis we had the same problem. Sometimes the ABS and brake light would be on, ABS and TC in-op, could not connect to it with a scan tool. When the lights weren't on everything worked, could connect with the scan tool, no codes and good wheel speed signals. Replaced the module with a Junk Yard unit and everything has been working for the last 1 1/2 years.
    Yes you can drive the car w/o the module installed but it would be a good idea to cover it to keep it clean.
    I suspect the problem is likely a bad solder joint as our car seemed to be most likely to have the problem the higher the ambient temps.
  1. Fog lites intermittent
    By Pat in forum Shop Talk
    Last Post: 08-27-2016, 05:43 PM
  2. Methanol Lites Them Up!
    By sailsmen in forum Power Adders
    Last Post: 02-12-2016, 11:58 PM
  3. Illuminated interior door handles
    By Dereck in forum Interior Electrical/Electronics
    Last Post: 08-12-2014, 11:47 AM
  4. Great Xmas lites near Fairfax VA ???
    By Thomas C Potter in forum The Lounge
    Last Post: 12-12-2009, 08:23 AM
  5. Help Guage Lites
    By sailsmen in forum Shop Talk
    Last Post: 12-14-2006, 01:48 PM
