Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 54
Thread: 10spd auto in a panther chassis
  1. #16
    Sep 2018
    Carrollton, TX
    My biggest b!t ch is the auto-start/stop and the fact Dorf made it so it can't be shut off permanently (yet again another example of taking control away from the consumer). One of my clients is a tech at local Ford dealer, he says people hate it and complain all the time. Told me 1 way to permanently disable it is to leave a trailer light test plug plugged in all the time. Haven't tried yet, will as soon as I find one
    The auto start/stop contributes to the fuel economy ratings of the cars, hence why it can't be permanently disabled. The heavy hitters at Ford knew this would be an unloved feature which is why you have the option to temporariliy disable it but had they made that a permanent on/off switch then you couldn't really say it benefits the car's EPA rating. People are resistant to change so to a degree the manufacturers have to shove a little tech down our throats from time to time.
    2003 Mercury Marauder 300A
    Former Owner: Joe Walsh
    2015 Mustang GT PP
    Guard Metallic Exterior
    2018 F-150 King Ranch
    2WD, 3.5 EcoBeast
  2. #17
    Quote Originally Posted by Logan86 View Post
    Just wondering....
    Do any of the manufacturers who offer this feature, 'beef up' the starter motors to account for the umpteen thousands of extra starts that occur because of it?
    (Or are they just planning on selling a LOT of starter motors over the parts counter...)
    Sorry to OP for the thread HiJack....10 speed in a Panther is a very cool mod!
  3. #18
    Oct 2005
    West 'burbs Chicago
    Just wondering....
    They do. The regular cars I believe also stop the cranks at certain positions to start easier. I am not a fan, but can see why they went this route to save fuel if the cars are only made to last 10 years.
    The 2019 RAMs though use a new 48v motor/generator as the alternator replacement called eTorque made to start the engine during these pauses, as well as a hybrid propulsion device of about another 100ft lbs of torque.
    But boo to new technology right... because 70s chassis' and 4 speed autos.
    '21 F150 XLT 5.0 Sport
    '18 Chevy Malibu Redline
    '10 Harley Ultra Limited
    '08 Kawasaki ZX6R
    '03 Grand Marquis(sold)
  4. #19
    I have the option to turn the stop/start feature off on my daily..and it is off.
  5. #20
    Jan 2013
    Indiana
    Quote Originally Posted by 2mercs View Post
    Check out forscan. I turned off the start stop, fogs stay on with high beams, and a few other things with the software.
    agreed... ForScan is a great tool and you can enable and disable most functions on most modules, EXCEPT the PCM
    I rebuild AOD/AODE/4R70W/4R75E Transmissions, check out my Facebook page for my latest project; https://www.facebook.com/pages/North...48414635312478
  6. #21
    Oct 2014
    Cunningham, Kansas
    The start and stop feature also requires an AGM battery. Ford parts catalog says warranty is no good on Motorcraft BXT flooded batteries if used on vehicles with stop and start. Of course the AGM Motorcraft batteries are about $50 to $60 more than their flooded counterparts.
  7. #22
    Sep 2006
    Psych ward
    I think its good that shift 6 is actually doing one.
    as for the complaint about the 10 speed shift how its unsure what gear its in, a good tuner can fix all the little issues.
    • 82 GT coyote swap started
  8. #23
    Sep 2018
    Carrollton, TX
    Just wondering....
    They do. Personally, I think it's a bit gimmicky and it kind of bugs me since every mechanical fiber in my body goes tense when a vehicle "dies" at a stop but so goes progress.
    Back on topic though, I am going to have to transplant a 10 speed in your Marauder (you have legacy ownership) if this ever becomes a plug and play option.
    2015 Mustang GT PP
    2WD, 3.5 EcoBeast
  9. #24
    Wisconsin
    It says the majority of adapters are real bad clones that don't work.
    Which adapter do you have & where did you get it?
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  10. #25
    Dec 2013
    NE Ohio
    Amazon. OHP ELMconfig OBD2 to USB ELM327 Adapter with MS-Can & HS-Can Switch and Forscan Compatible for DIY Ford Diagnostics on Windows https://www.amazon.com/dp/B01F0GVBWY..._xNu7BbPQ6F8A1
  11. #26
    Go for it!
    That would be a sweet mod.
    (drop in a 5.0 Coyote with the 10 speed to make the swap easier...)
  12. #27
    Jan 2013
    Indiana
    Yep, thats the one you want.
  13. #28
    Wisconsin
    I figured that but if they really cared about CAFE they would have supercharged some of the 4.6 vehicles and gained an easy 2mpg to factor in to CAFE.
    The ASS (appropriate acronym) will result in fuel savings if you live in LA but it does NOTHING for everyone living in a non-gridlocked urban area.
    I'm not about to burn up a $1000 starter to save a tablespoon of gas.
    I have a client at my local Ford dealer that is a tech and he tells me that EVERYONE complains about and HATES the ASS.
    I'm not resistant to change when it's good but sure as h ell will when it's bad. To blindly accept change = serf or lemming.
    If I could have gotten the M/T I wanted you wouldn't have heard me complain about the 10sp... But that's a whole other thread...
    Sorry to OP about the thread hijack. As ya'll were. :-)
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  14. #29
    Wisconsin
    When you start the vehicle the next time is it still off?
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  15. #30
    Wisconsin
    Quote Originally Posted by hotford View Post
    True but:
    • a person shouldn't have to pay someone the to "fix" the issues on a $50,000 truck that the manufacturer had the ability to "fix" but couldn't be bothered to do
    • This is a lease (I will not own anything manufactured after 2010) so as I'm renting it I can't mess with it
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  1. Chassis lubrication?
    By tylerdurden2816 in forum The Lounge
    Last Post: 10-13-2014, 04:08 PM
  2. Chassis Oil spray???
    By Thomas C Potter in forum Shop Talk
    Last Post: 10-21-2013, 09:01 AM
  3. AWD 4WD chassis
    By Aren Jay in forum Shop Talk
    Last Post: 08-25-2008, 06:15 PM
  4. Chassis and Marauder
    By Aren Jay in forum Community Discussion
    Last Post: 07-18-2008, 07:08 PM
  5. Panther chassis related news from Ford...
    By GreekGod in forum The Lounge
    Last Post: 06-24-2006, 05:45 AM
