Results 1 to 15 of 23
Thread: Spongy Brake Pedal
    Feb 2006
    Rosemount, MN
    Spongy Brake Pedal
    The brake pedal on my Marauder is really spongy. There is a lot of travel before the brakes begin to grab. And it seems like if I keep pushing, the pedal keeps moving towards the floor. I have the TCW SS brake lines, so I know it's not rubber hoses expanding. The brake fluid lever is fine. I also flush through new brake fluid each spring.
    Is this a bad master cylinder or vacuum booster?
    Thanks,
    Curt
    May 2009
    Moreau Island
    Rotors and pads are in good shape?
    Feb 2006
    Rosemount, MN
    Yes. New front rotors last spring and I run Carbotech AX-6 auto cross pads on all four corners.
    Jun 2007
    Bethlehem, PA
    If it’s spongy, it could be your master cylinder. Typically when a booster fails, the pedal gets hard.
    2003 DBP # 153 Whipple 3.4 in coming soon
    2004 Black Trilogy #43
    May 2003
    Waterloo, IA
    Or you need to bleed the brakes again...
    Feb 2005
    Clermont Florida
    I am having the same issue. I read that this could also be caused by the ABS system. My plan is to get a 10 and 12mm brass plug and plug the master cylinder and see if the pedal firms up and doesn't slowly go to the floor. I am afraid if it doesn't go to the floor I will be in real trouble because ABS parts are hard to come by for our cars.
    Performance
    4:10's, rear Adco, front Eibachs w/ KYB struts, Working oil pressure gauge, JLT CA Kit, Fumoto Oil Drain Valve, Remote Oil Filter, TCE SS Brake Lines, Prostop drilled and slotted rotors.
    Dress
    2009 Hyundai Sonata DD
    2007 Chrysler Pacifica
    2003 Marauder 300B RIP
    LOC: Clermont Florida
    Wisconsin
    Quote Originally Posted by TooManyFords View Post
    This, with ABS pump cycle.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    ABS delete
    http://www.prbmachining-absdeleteman...talog/i43.html
    Feb 2015
    South Florida
    Install SS brake lines, you will feel the difference.
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15.
    Feb 2006
    Rosemount, MN
    Quote Originally Posted by Gerry24 View Post
    Already have the TCE SS brake lines.
    Feb 2006
    Rosemount, MN
    I'm not familiar with this. Can you provide some additional information?
    Wisconsin
    Air gets trapped in the ABS pump/lines which makes pedal spongy even after bleading brakes many times.
    Take to dealer for bleed with ABS pump cycle or get a scan tool that cycles pump and do yourself.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
    Sep 2018
    Carrollton, TX
    I had a similar situation and it was a failed master cylinder. Bench bleed, go get the ABS bleed down at a dealer and then enjoy a nice firm pedal again.
    2003 Mercury Marauder 300A
    Former Owner: Joe Walsh
    2015 Mustang GT PP
    Guard Metallic Exterior
    2018 F-150 King Ranch
    2WD, 3.5 EcoBeast
    Feb 2006
    Rosemount, MN
    Rock Auto lists a Raybestos, Cardone, Centric or AC Delco master cylinder. Anyone have any recommendations? Or how about NAPA?
    Feb 2019
    Youngstown, FL
    I have the same problem now. My OEM brakes on the 2003 Marauder feel mushy and inadequate for a fast stop. Scared the hell out me a couple of times...almost had to take the ditch to avoid collision.
    I was looking to upgrade brakes. Has anyone had any experience with the Power Stop® Z23 (or Z26) Evolution Drilled and Slotted Brake Kit with Calipers?
    https://www.carid.com/2003-mercury-m...574631010.html
    HL
  1. Brake pedal repair
    By sam in forum Shop Talk
    Last Post: 03-01-2018, 07:04 PM
  2. Wanted To Buy brake pedal pad
    By stevengerard in forum Marauder Parts/Misc. Wanted
    Last Post: 01-27-2017, 12:04 PM
  3. Low brake pedal
    By bugsyc in forum Steering, Suspension & Brakes
    Last Post: 09-24-2016, 01:50 PM
  4. Brake pedal noise
    By chucky in forum Steering, Suspension & Brakes
    Last Post: 09-07-2011, 02:43 PM
  5. Low brake pedal
    By Matt In Detroit in forum Steering, Suspension & Brakes
    Last Post: 08-07-2010, 10:13 PM
