Page 7 of 7 FirstFirst 1234567
Results 91 to 94 of 94
Thread: Will be swapping in a built 99 Cobra engine.
  1. #91
    BTW your cooling mod hose is too long.
    Good catch. Probably a wicked air trap as well.
  2. #92
    Aug 2010
    Gadsden, Al
    Look at the arrows on the check valves to verify they are functioning as designed
    PCV side: the arrow should point towards the intake
    DS: arrow should point towards the engine
    If you set them correctly once you get into boost the PCV side will draw closed (preventing boost from entering the engine).
    The GT500 PCV valve will catch anything that gets past the check valve. (fail safe)
    The DS check valve will stop any oil blown from the engine from entering into the CAI track
    The system is correct and should perform well.....
    Thanks musclemerc. I did verify the check valves were correct during installation and the orientation matches what you suggested. I do agree that hose is too long. I have plans to shorten it before adding coolant and starting the engine. Didn’t think about it being an air trap, but it’s just simply too long. Thanks for the help
  3. #93
    The Dirty South
    Put the cowl on before you cut it.
  4. #94
    Aug 2010
    Gadsden, Al
    What oil do you guys recommend for engine break in. I’m familiar with some type of non detergent oil but wanted to check with the pros before doing so. Not even sure if that even relevant in engines of today’s time. I used havoline when I built the 347 in my Mustang.
  1. Swapping a Cobra motor into a Marauder
    By sflrainmaker01 in forum Power Adders
    Last Post: 06-12-2015, 08:15 PM
  2. For Sale 04 cobra built Aluminum 4.6 4V motor, built T56, Blower, and much more
    By ctrlraven in forum Other Parts for Sale
    Last Post: 11-15-2010, 11:20 PM
  3. Engine Swapping Question
    By MENINBLK in forum Shop Talk
    Last Post: 11-24-2006, 09:34 AM
  4. 1999 PI Vic Cobra/5 Speed built by Roush
    By maraudernkc in forum Forced Induction Technologies
    Last Post: 11-16-2006, 05:52 PM
  5. Replies: 3
    Last Post: 07-03-2006, 01:50 PM
