Results 1 to 3 of 3
Thread: New Ford Crate Motor Complete: 2004 SVT Cobra Supercharged Engine & Accessories!
    Jul 2015
    Livermore, Ca.
    If it has been sitting for this long, might need a tear down anyways. Gaskets tends to get hard and crack correct ?
    Still a nice pickup for somebody.
    https://www.ebay.com/i/254184265364?...407365ffed04ed
    Gaskets plus....because they 'forgot about it' certain valvesprings have been fully compressed for 15 years.
    For 14K, I'd rather buy a 5.0 Coyote crate motor, save 6 grand, and make more power N/A.
    Great buy if you wanted to restore/resurrect
    an '03/'04 SVT Cobra.
    Sep 2006
    Psych ward
    13,900 nah....found a 1600 mile complete with trans and harness, pcm and cluster for 8K!!
    how do ya forget you have a cobra motor...........FCK up!
    • 82 GT coyote swap started
  1. The Build: 2004 Miata Mazdaspeed w/LS3 crate motor
    By Invective in forum The Lounge
    Last Post: 01-13-2019, 11:57 AM
  2. Replies: 10
    Last Post: 06-12-2014, 07:22 PM
  3. Another 03 Cobra Crate motor Novi 1500 sold
    Last Post: 05-10-2011, 02:23 PM
  4. 04 Cobra crate motor project
    Last Post: 01-18-2008, 10:01 PM
  5. Cobra crate motor in MM
    By prchrman in forum Community Discussion
    Last Post: 03-30-2003, 09:40 AM
