Results 1 to 15 of 20
Thread: 2003 Transmission
    May 2019
    Pa
    2003 Transmission
    Hello all. I have a 2003 Marauder with a bad transmission and I am having one heck of a time finding a replacement. I know mine has a 4R70W with the long tail housing and tail shaft. I have found some other 4R70W’s but they have the short tailhousing. Does anyone know which specific vehicles have the same tranny that I can swap into mine? I pulled mine out and of course it doesn’t have the ID plate on it so I don’t know what number it’s supposed to have. I’ve been told certain police interceptors have the same tranny and some grand marquis along with 03 Lincoln towncars. I found a 2003 Lincoln towncar but the tranny is still in the vehicle and it’s quite a haul to go there to measure the tail housing hoping it’s the right one. I did call ford and they verified it is a 4R70W but they cannot tell what tailhousing it has. They did provide me with the number plate that should be on that car though which is 3w1p-7000-ca. Anyone know if that’s the same tranny? Thank you!
    Its the same as p71 , limo, and yes some town cars.
    Have you tried www.car-part.com?
    i just searched there and is see some for above and below 200.00...
    Might score one locally for a 2003 marauder.
    If you buy a 2004 you will have to buy a tuner and change the parameters between the oss occ? tooth count...
    The civilian MGM and CV have the short shaft..
    Jan 2018
    Califon NJ
    I also had a hard time finding one last year. Needs to be from '03 marauder or CVPI. I didn't know about limo or town car but an easy indicator is the 1 piece aluminum drive shaft. The steel 2 piece shaft works with the shorter housing.
    Another option is a 4r70w with the shorter housing and a 1" spacer that goes between the drive shaft and pinion yoke.
    May 2019
    Pa
    Thank you for the replies. When I called the ford garage they said my tranny would have a plate ID of: 2w3p-7000-aa. I will have to see if the town car has a one piece driveshaft.
    you can swap tailshaft housings
    May 2019
    Pa
    But don’t I have to swap the shaft as well? I heard you have to tear the whole tranny apart to get the shaft out.
    you put your long tailshaft housing on if the trans has a short one..short is for steel driveshaft, longis for aluminum..it bolts on the rear of then trans..6-8-10 bolts?
    Quote Originally Posted by ajp89 View Post
    i have read the same thing
    ok, the correct way is to swap tail shafts in the trans, but there is another way read here.
    https://adtr.net/kb/crown-vic-driveshaft-swap/
    That clicky is how to convert a steel driveshaft car to aluminum.
    Are you suggesting he finds a civilian short tail shaft transmission and using the adtr adapter on the mm shaft?
    I do not see prices, i wonder how much they want for the adapter.
    Cheers
    Apr 2010
    South Florida
    Get the correct transmission. 03 Marauder or CVPI.
    Cheers
    It's an option..CV guys put cvpi driveshafts into their lx and Marquis all the time. Or he can spend $2000 and get it rebuilt which is what I would do. **** used trans, rebuild it right the first time
    Feb 2015
    South Florida
    Just have to find a reputable tranny shop, which hard to come by these days.
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15
    SOLD
    Jun 2009
    Warsaw, Indiana
    Quote Originally Posted by Gerry24 View Post
    I happen to have a long tail shaft housing and a balanced cvpi drive shaft I might be willing to sell. If you're interested p.m. me and I will give you the details.
    Hiram, Georgia
    What about the number of holes in the transmission?
  1. Wanted To Buy Transmission 2003 dipstick tube
    By Lucid5meodmt in forum Marauder Parts/Misc. Wanted
    Last Post: 08-08-2017, 08:25 AM
  2. For Sale 2003 Mercury Marauder needs Transmission - $2,800 obo
    By Mrauder83 in forum Marauders for Sale
    Last Post: 03-15-2017, 08:49 AM
  3. For Sale 2003 Marauder 4.6L DOHC Engine & Transmission
    By CrownVictorious in forum Marauder-specific Parts for Sale
    Last Post: 10-16-2016, 06:11 AM
  4. 2003 marauder transmission
    By paSS in forum Transmissions
    Last Post: 05-19-2011, 06:38 PM
  5. FS: 2003 Marauder transmission
    By Serge in forum Marauder-specific Parts for Sale
    Last Post: 07-06-2008, 05:09 AM
