Results 1 to 5 of 5
Thread: rear seat removal
    Nov 2006
    Union City, CA
    rear seat removal
    Does the Marauder rear seat remove the same way as older Crown Vics?
    I want to finally put the seat covers from seatcoversunlimited on properly. And I know from my 30 year old Vic that the bottom just pops out and the back has some starbit bolts near the bottom edge but the top just pops out. Have also seen from pick n pull how easy it is to warp the seat foam by pulling it out too hard.
    I tried first to pull the Marauder rear seat bottom out but pulling without too much force, it hasn't popped out yet. Didn't want to apply too much force. You have to remove the bottom to access the screws for the seat back, right?
    1988 LTD Crown Victoria S
    Lehigh Valley, PA
    Bottom seat pulls up and out, if yours has never been out you'll have to pull really hard.
    2063/3214
    5377/7838
    Apr 2010
    South Florida
    You can pull it up front the front to pop it out, to get it back in You have to push it back and down till it latches. You'll see the hooks when You pop it up. Then You'll see the seatbelt bolts holding down the back part. You lift that up as well.
    rear seat removal
    From what I remember push in (pushing the bottom towards the rear), then up.
    Push back and pull up for the bottom cushion, the seat back has 2 18mm nuts holding it at the belt attachment point on the floor
    Trilogy # 192 / T.S. 0012
  1. Wanted To Buy Lower Rear Seat and Drivers Seat
    By Greg in forum Marauder Parts/Misc. Wanted
    Last Post: 02-01-2019, 08:06 AM
  2. Rear seat removal
    By offroadkarter in forum Community Discussion
    Last Post: 03-21-2008, 05:06 AM
  3. Driver's seat removal
    By Eric91Z in forum Shop Talk
    Last Post: 04-06-2007, 05:41 PM
  4. Rear seat (bottom) removal
    By CRZYBIKER in forum Shop Talk
    Last Post: 01-17-2007, 04:01 PM
  5. Passenger Seat Removal
    By blkgrape in forum Community Discussion
    Last Post: 09-29-2003, 10:32 PM
