Results 1 to 7 of 7
Thread: Air Bag Control Module
    Dec 2007
    New Jersey (south)
    Air Bag light stays on, local mechanic says it's the Air Bag Control Module and that he can't find one. Want to buy the control module.
    5.0 Stroker 850 mod from MMR
    Metco Billet upper and lower control arms
    4.10 Ford Motorsport gears
    Custom tune from Paul at Collingdale Performance
    Eibach lowering coils
    Aeroforce multi function gauge
    Good luck programming it
    clock spring
    I would find a new mechanic too.
    Lehigh Valley, PA
    You haven't messed with it at all have you? If the unit isn't grounded it'll keep the light on and throw an airbag code about something related to power (don't remember the exact code). I had mine floating around when I did the manual swap and my airbag light was on, when I bolted it down to the remnants of the center console bracket the light went off and has been off for 2 years.
    Clock spring would also be possible as well but I'd expect the horn/cruise to not work.
    I do have an airbag module out of a 2004 Sport if you end up needing to swap it.
    2063/3214
    5377/7838
    Contact blackened300a, I believe he has an RCM and two front crash sensors
    Feb 2005
    DC MD Area
    My car was in a accident two years ago, the driver side air bag diployed and I had to get the RCM reset and my driver side seatbelt. I sent it off to this company in Georgia https://www.myairbags.com/ to get it reset. I also replaced the clock spring and the crash sensors. If you never had a accident where your airbag deployed just get a scanner that can read ABS and it'll tell you what the problem is. The RCM goes with the code of your car. Mine is BMD0....
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
  1. Wanted To Buy Cruise control module
    By BigM460 in forum Marauder Parts/Misc. Wanted
    Last Post: 11-10-2014, 01:09 PM
  2. In need of a/c control module
    By texas1 in forum Shop Talk
    Last Post: 08-17-2013, 07:14 PM
  3. Blower Control Module gone bad?
    By RubberCtyRauder in forum Shop Talk
    Last Post: 08-22-2011, 07:27 AM
  4. Headlight Control Module
    By jsignorelli in forum Community Discussion
    Last Post: 08-17-2011, 08:34 PM
  5. Wanted To Buy AC control Module
    By hispdvic in forum Marauder Wanted
    Last Post: 02-02-2010, 05:06 PM
