Results 1 to 8 of 8
Thread: Snap On Ethos can control and Adjust Rear Air Height
    Nov 2012
    Sacramento
    Mechanism used SNAP On Ethos tool, to cycle my air bags (inflate and deflate) and to adjust rear ride height. It was soooooo cool to adjust the rear ride height while standing next to car pushing "button" on screen.
    So easy and effective! See suspension write up for more info.
    Aug 2018
    Somersworth New Hampshire
    I just bought the snap on Ethos. Gonna have to give it a try.
    Thanks...
    03 black 300A # 2827 stock setup 270,000 miles and going.
    Rear cat delete. Magnaflow 11256 mufflers.
    Hiram, Georgia
    But when it’s disconnected it goes back to the ride height sensor, correct?
    Nov 2012
    Sacramento
    No it stays where it is set when unplugged from unit. Was mind blowingly cool to so easily set, after my four manual four slog last time.
    Feb 2005
    DC MD Area
    Hmmmm but I thought the lil adjustment slide controls it. When with the ethos doing what it does it should be set that way b/c the slide controls it.
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
    Quote Originally Posted by NATEHAWK View Post
    Probably does reset after cycling the key? I canít see how it couldnít?
    Hiram, Georgia
    This was my point.
    Jun 2008
    Waukesha, WI
    I assume the ethos temporarily overrides the ride height sensor so you can manually set the height. Then adjust the sensor on watts link with the ethos holding the desired height.
    2004 300A Procharger #0010 P1SC, now D1SC.
    2003 300A Procharger #0017 D1SC (SOLD)
  1. rear height
    By MdnightMarauder in forum Shop Talk
    Last Post: 12-12-2009, 04:44 PM
  2. Rear Ride Height
    By DWSTANG67 in forum Tires & Wheels
    Last Post: 04-03-2008, 03:05 PM
  3. rear ride height
    By kj31067 in forum Community Discussion
    Last Post: 10-10-2006, 09:13 AM
  4. Rear End snap/creek
    By Digital Man in forum Shop Talk
    Last Post: 09-22-2005, 01:05 PM
  5. Rear Ride Height
    By rocknrod in forum Shop Talk
    Last Post: 06-03-2005, 01:17 PM
