Results 1 to 9 of 9
Thread: stock wheel stud length, good length for rear wheel spacers 1/2 inch?
    Aug 2018
    Indianapolis
    redoing the rear end, while I am at it i ordered a bunch of new stuff.
    looking to get some rear wheel spacers but trying to decide what wheel studs to get to have the right amount of length with a 1/2 inch spacer.
    also any recomendations on spacers?
    I ordered MOSER msr-8050 wheel studs awhile back, dont know if they will be long enough or if i need to order others.
    thanks for any advice.
    Blog Entries
    2
    Why need spacers?
    Timbuk3, MI
    Exclamation
    • hub-centric
    • HIGH QUALITY
    • recommend H&R or Eibach *Have used both.
    Aug 2018
    Indianapolis
    make the rear tires look flush with the body and the slightly wider stance looks cool in my opinion.
    also i had already bought the moser wheel studs and after looking at the stock 2006 axles the studs are longer, by atleast half an inch.
    I was not sure if the marauder wheel studs are the same as all other panthers.
    I would like to get widened rear wheels some day anyway.
    thanks for the input.
    Can widen stock Marauder rear wheels to 9.5 with no issue, aftermarket can go wider with correct offset so it won't interfere with rear shock. Just be Aware that if you push the sxce of wheel and tire out, if your rear air suspension fails and you lose air, then you will most likely have fender to wheel contact possibly causing body damage and tire damage
    Aug 2018
    Indianapolis
    Thanks for the insight towards a potential problem.
    I only want to exten maximum 1/2 inch, 3/8 would be fine also I suspect.
    I like the Eibach spacers. I just want to verify the length of my rear wheels studs as appropriate. for either 1/2 inch or 3/8 thick spacer.
    the moser wheel studs are MSR-8050 7/16-20x2-7/8
    I am installing brand new arnott bags and seals with a compressor rebuild. Hope that will offer a little insurance.
    is there anything that can be done to prevent bottoming out?
    I went with the monroe magnums because they have the 2oz and support spring.
    Nov 2017
    Blue Springs Missouri
    For proper lug nut engagement you need the same in thread length as the diameter of the stud. So if it’s a 1/2” diameter stud you should have 1/2” of thread engagement after you’ve installed your spacer. Hopefully that makes sense.
    Sep 2010
    Western WA
    Quote Originally Posted by Blakshukvw View Post
    To expand on this since the studs are 1/2-13, ie 13 threads per inch you want at least 6.5 turns of the lug nut before it gets to the point where you are really tightening it.
  1. Rear axle length?
    By Lowndex in forum Steering, Suspension & Brakes
    Last Post: 01-03-2016, 07:17 AM
  2. Ultimate ported, stock runner length intake
    By na svt in forum Shop Talk
    Last Post: 01-31-2012, 09:51 AM
  3. Wheel spacers on stock Rim
    By kmastl in forum Tires & Wheels
    Last Post: 10-17-2011, 06:21 PM
  4. Rear passenger wheel stud snapped off.
    By ldawg in forum Steering, Suspension & Brakes
    Last Post: 06-01-2011, 04:57 AM
  5. Widened wheel spacers
    By DOOM in forum Tires & Wheels
    Last Post: 12-04-2010, 12:25 AM
