As an engineer with years of experience in the steel forging and foundry industries, I can tell you that an unreinforced stamping can never be as strong as a forging. That is why replacing the stamped steel rear suspension arms with machined billet or forged parts makes such a dramatic improvement in handling. Stamped steel parts have one advantage for the car manufacturer, which is that they are cheap to make. Just sayin'.
