Results 1 to 4 of 4
Thread: 2005 6-speed auto
    Aug 2003
    Battle Creek, Michigan
    2005 6-speed auto
    The 6-speed in my 2005 Montego has been experiencing hard downshifts recently. Only after it's warmed up, and mostly at lower speeds. Sometimes it really bangs into gear, and may shudder approaching stops. Are these signs of impending doom?
    First retailed 2003 Marauder
    Bought 6 June 2002
    #168
    Sep 2006
    Psych ward
    You sure it's a 6 speed, maybe a 5 speed auto trans, 6 speed wasn't out till 2010.
    • 82 GT coyote swap started
    Aug 2003
    Everything I have, or can find says it's a 6-speed
    Bought 6 June 2002
    #168
    Jun 2017
    Oxford, PA
    I have a 2010 Milan, had a rough shift, I drained and refilled the transmission fluid, shift issue went away. It was Mercon LV fluid and IIRC about 3 qts came out. Have to take off the plastic shroud then it is easy as an engine oil change. No filter to change.
  1. 6 Speed Auto in a Marauder?
    By TUXrauder in forum Transmissions
    Last Post: 03-21-2012, 08:56 AM
  2. 6 speed auto transmission
    By lhemphill in forum Site Questions and Suggestions
    Last Post: 10-11-2011, 07:31 PM
  3. 6-speed auto
    By Georges93LX in forum Transmissions
    Last Post: 10-12-2010, 06:08 PM
  4. 2005 Washington Auto Show
    By MyTMerc in forum North East Marauders
    Last Post: 01-02-2005, 06:09 PM
  5. Med. speed auto x in Lake Geneva WI.
    By RobSS96dcm in forum Windy City Marauders
    Last Post: 08-10-2004, 01:59 PM
