Results 1 to 10 of 10
Thread: Torque converter suggestion wanted
    Quebec
    I want to replace the stock converter. N/A car SCT tune for 91 with 4.10, any suggestion would be greatly appreciated.
    Thanks
    > have you hugged your Marauder today <
    Dec 2014
    Hastings, mi
    I was pretty happy with the budget circle d when I still ran the 4.6/4r setup. But that was like 5+yrs ago. So I'm not sure if it's the same now vs then. Good convertor is worth spending the money on.
    I had used a oe style one in a previous vehicle that I purchased from transtar. I don't recall the manufacturer. But it blew up internally and wiped out my transmission a thousand miles after a complete and thorough rebuild. Sucks spending that $ twice.
    https://www.circledspecialties.com/4...-series-11inch
    1.56 60' 6.90 1/8 @ 101 mph 10.7 1/4 @126 mph
    #BSTDMRC #LSSWAPPEDMARAUDER
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
    Blog Entries
    2
    I have had a Precision Industries for 180+ miles and 225+ 1/4 Runs. 3,000-3,500 stall. As respects a High stall it's all in the Tune.
    195,000 Miles & 275+ Runs Down the 1,320
    Vortech Super Charger V-2 T Trim, 19 PSI
    Feb 2017
    New Orleans, LA
    I highly recommend a 4k stall
    Lehigh Valley, PA
    Can't go wrong with a Circle D. It was the direction I was headed til my auto died
    that sounds horrendous in a mild street driven car. I hated the 3500 stall converter in my friends 96 impala SS.
    2016 Ford Mustang GT PP - Lund nGauge, BMR vertical links
    2003 Mercury Marauder - Stainless Works LT's, Stainless Works 2.5" Catback, JLT Intake, Mo's Xcal4 Tune
    5377/7839
    Feb 2017
    New Orleans, LA
    thats a completely different vehicle and engine
    The pcm in the marauder is capable of dithering the converter so unless your in the throttle there is no possible way to tell the difference between a 4k stall and a stock converter it will drive 100% identical when calibrated correctly.
    Apr 2010
    South Florida
    2800-3k from MartyO is what I have with 4.10s. I like it a lot. Fine for daily driving great for racing.
    Quebec
    It's very mixed, I was expecting something more straight
    Jun 2008
    Waukesha, WI
    Most here get a 3k stall. Precision Industries, Circle D, or one from Marty. There's not much more to say on this.
    2004 300A Procharger #0010 D1SC.
    2003 300A Procharger #0017 D1SC (SOLD)
    Oct 2014
    Charlotte, NC
    I have the 3k Circle D with my mods, per MartyO's recommendation. Right on target IMO.
    Current Garage:
    2004 DTR Marauder
    2005 Mustang GT Premium
    2008 Triumph Sprint ST
    2015 Triumph Trophy SE
    Life is 10% what happens to you and 90% how you react to it.
    Charles R. Swindoll
  1. What is the stall on the Torque Converter?
    By cyled in forum Shop Talk
    Last Post: 02-04-2003, 06:32 PM
  2. Torque Converter v Gears
    By cyclone03 in forum Shop Talk
    Last Post: 02-02-2003, 01:09 AM
  3. Catalytic Converter
    Last Post: 12-25-2002, 07:11 PM
  4. Torque Converter - Headers
    By mensrea in forum Community Discussion
    Last Post: 11-01-2002, 05:41 PM
  5. Low end torque
    Last Post: 09-24-2002, 07:02 AM
