Results 1 to 15 of 18
Thread: Water pump pulley
    Jun 2019
    Euless
    Water pump pulley
    I noticed some of ya'll put a high flow emp stewart water pump. i did the same and ran into a pulley issue the old one wont fit and the new one i got that dose fit the water pump is to big, any advice?
    Apr 2010
    South Florida
    Post a pic. Did You get the short or long pump? Only issue I had with a Steeda water pump pulley was I had to add washers on the bolts to back them out a bit so it would spin freely.
    Jun 2019
    Euless
    It's a short
    Sent from my SM-G970U using Tapatalk
    Oct 2003
    Beaufort, SC
    Send it back and get an OEM type replacement!!
    I never saw any improvement with the Stewart pump but it did seem to work OK just too expensive!!
    Member #1368
    2004 Silver Birch...300A
    #948 of 3213/#8787 of 11052
    FIT "ProCharger" #0010
    Real AutoMeter Oil Pressure Gauge
    Addco Anti-Sway Bars
    ScanGauge II In Dash
    Nitto 295's On Widened Rears
    Mach I Air Dam
    Jan 2015
    Mishawaka, In
    What makes it high performance?
    Apr 2010
    South Florida
    Quote Originally Posted by mm svt View Post
    It's a 6% improvement in flow at 6,000rpm while consuming 7% less power. It will out flow the stock pump while consuming less power to run it.
    Apr 2010
    South Florida
    Quote Originally Posted by Bozsbone View Post
    It's a short
    Neither of those fit? The stock one should but I've never tried it. Where did You get the top pulley?
    Oct 2003
    Beaufort, SC
    Any improvement with the EMP Stewart pump is not really measurable!!
    It is quite well made but a lot more expensive than OEM so save your money for a more meaningful modification!!
    Member #1368
    Mach I Air Dam
    Timbuk3, MI
    Lightbulb
    03Merc - It's a 6% improvement in flow at 6,000rpm while consuming 7% less power. It will out flow the stock pump while consuming less power to run it.
    And how much time do you plan on spending in the 6000RPM zone? *Just sayin'.
    Jun 2019
    Euless
    Top one fits the waterpump too big for engine I got it from summit
    Jun 2019
    Euless
    My uncle says I need it to move water quicker it's over heating, it's an different engine and has cams
    Apr 2010
    South Florida
    Quote Originally Posted by gdmjoe View Post
    Just stating a fact. Regardless, it's an upgrade.
    Oct 2014
    Cunningham, Kansas
    Sometimes moving coolant too fast is bad also, really fast flowing coolant might not have time to pick up the heat and then release it at the radiator. Just saying....
    2004 SB #2150 of 3214 Moonroof, Heated Seats and 6 CD Changer. Non OEM Mufflers and 31,XXX miles and counting.
    Feb 2011
    New Jersey
    Quote Originally Posted by Fastbob View Post
    Very interesting
    The Dirty South
    Pretty sure Stewart took all that into consideration when they desighed and tested the WP before its release.
    I've run this pump for 10 plus years without a single issue. Did I choose this unit for the advertised 2-3HP gain? No I did it because the impeller design is far better than the stock wagon wheel.
  1. Fuel Pump?
    By gdsqdcr in forum Shop Talk
    Last Post: 07-09-2019, 01:03 PM
  2. Replies: 5
    Last Post: 07-03-2019, 12:11 PM
  3. Power Steering Pump noise
    Last Post: 11-13-2004, 09:19 AM
  4. Water leak
    Last Post: 09-28-2003, 12:54 PM
  5. Water runs down fireWall over cat. converters.
    By warren in forum Community Discussion
    Last Post: 08-22-2002, 09:02 AM
