Results 1 to 3 of 3
Thread: Audio/Alternator/Overcharging Problem, looking for advice.
    Jun 2017
    Essex County, Massachusetts
    Need a little help with an electrical problem. Recently had an audio system installed with speakers, subs and an amp. It was done by a reputable audio place, not a teenager at best buy. Long story short, I took the car into my mechanic for what I thought was a battery/alternator problem. (Car would not start if sat for longer than 3-4 days) They tested the battery and said it had a dead cell. and said my alternator was only charging at 13 volts. I replaced the battery, and had the alternator rebuilt. With new battery and rebuilt alternator, it was overcharging the battery at 17 volts. The only way my mechanic could stop this was to disconnect the amp for my subs. Taking it back to the audio installer, but curious if anyone has any ideas? Thanks in advance.
    Feb 2014
    birmingham, al
    Make sure the amp has a good ground, if so try a new grounding spot
    Jun 2017
    Thanks for the input, When I picked the car up from my mechanic I drove it straight to the audio installer. He touched the disconnected amp wire to the battery, which powered up the radio/subs, and tested the battery simultaneously. It stayed right at 14.7, even with me revving the engine up. He left it disconnected and told me to drive the car for a few days to make sure everything is normal and then I will leave it with him for a day to sort out whatever could be going on. I will mention checking the ground wire to him for sure. thanks again.
  1. Trunk / Luggage Compartment light problem and or ?
    By jaywish in forum Interior Electrical/Electronics
    Last Post: 08-14-2019, 02:36 PM
  2. Alternator Regulator Part Number
    By pantheroc in forum Shop Talk
    Last Post: 07-11-2019, 04:26 PM
  3. shifting problem?
    By mark in forum Transmissions
    Last Post: 11-23-2016, 09:00 PM
  4. New member problem
    By Sidney in forum The Lounge
    Last Post: 02-05-2003, 06:29 AM
  5. Audio components
    By jjfingers in forum Community Discussion
    Last Post: 10-22-2002, 07:55 AM
