Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 55
Thread: 03 maurader spider gears?
  1. #31
    Lehigh Valley, PA
    Quote Originally Posted by Curless View Post
    The Marauder Carrier is all by itself, no parts are available for them. If your spiders are junk, throw the carrier away and replace it with an Eaton. No idea why Ford built a Marauder specific carrier but they did. Just had a 28 spline Fox body 8.8 apart, they are different from the Marauder...
    Yeah but a fox body carrier is also different from, say, a 99-04 new edge GT carrier. IIRC the fox body carriers are/were popular because you could wedge another clutch pack in there due to the design of the carrier.
    I do see looking up the PN that it only shows 03/04 marauder, that is really strange. Of all the things Ford invested money into for this car, why would this car need its own 28 spline diff?
    Apparently this seller has a NOS one on ebay
    https://www.ebay.com/itm/FORD-OEM-Re...75.c1#viTabs_0
    the L/S for a P71 of the same year (XW7Z-4204-BB) shows a year range of 84 to 2009 including box panthers, LTDs and Aerostars.
    2016 Ford Mustang GT PP - Lund nGauge, BMR vertical links
    2003 Mercury Marauder - Stainless Works LT's, Stainless Works 2.5" Catback, JLT Intake, Mo's Xcal4 Tune
    5377/7839
  2. #32
    Apr 2010
    South Florida
    Opened the box.
  3. #33
    05+ Crown vic 31 spline spiders are a direct fit. Toss in some axles and a Cobra clutch pack.
  4. #34
    Aug 2018
    Somersworth New Hampshire
    Did You ever try the kit I just posted about?
    I will check the part number when I get to the shop in the am. But to be honest it looked just like those and it didn't fit. I wish I could post pics not sure why I cant .
    03 black 300A # 2827 stock setup 275,000 on car. 65,000 on engine from a 04. 03 engine died at 273,000 . Rear cat delete with magnaflow 11256 mufflers.
  5. #35
    Aug 2018
    These are the gears that came out
  6. #36
    Apr 2010
    South Florida
    Quote Originally Posted by Maverick pro View Post
    Sheesh! Those are bad. How's the Pinon and ring gears!? Mine look like this...
  7. #37
    Jun 2007
    Bethlehem, PA
    If your car has 270,000 miles on it, it would probably be cheaper and quicker for you to find a low mile complete 3.55 locking rear out of a 06+ police car. At that many miles, I can’t see the axles or ring and pinion gears being in great shape. Swap the entire rear and be done.
    2003 DBP # 153 Whipple 3.4 in coming soon
    2004 Black Trilogy #43
  8. #38
    Aug 2018
    Ring and pinion look great. Replaced axles and bearings along with clutch packs. Thats how I found the trashed spider gears. Waiting on spider gears now.
  9. #39
    Aug 2018
    They look great considering. Not sure if they had been replaced before I bought the car.
  10. #40
    May 2004
    (The other west coast)Wyoming Michigan
    Any repairs without going to an Eaton (no clutch pack) differential is a waste of time and money. An Eaton Truetrac is probably best, although an Eaton Detroit locker is OK, too.
    Clutch pack diffs are a wear item - a Truetrac or Detroit Locker will never wear out or break (even a modified Marauder, with less than 750(?) horsepower, and sticky tires. The 31 spline axle shafts will break first)!
    Ask Curless - he knows, too
    ΓρεεκΓοδ
  11. #41
    Jun 2012
    Grand Rapids
    No, I have a pretty bad ass parts guy at my local dealer... Jerry was here with me when we discovered nothing is the same as any other 8.8 rear... The gears in a Marauder diff are different thicknesses than the other carriers...
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
  12. #42
    Aug 2018
    The gears summit just sent are not correct. Gonna go with a new carrier and stop trying to locate gears.
  13. #43
    Aug 2018
    Ok guys an update...got a complete used carrier from mustangeddie . The carrier and gears are from a 98-04 mustang. Everything works perfect as it should. I did rebuild the clutch packs but the ones that came with the used carrier looked ok so they will be spares for the future.
    Thanks again to everyone who helped me get this figured out. I would have never guessed the marauder had a marauder specific carrier and gears. But I've definitely learned something new about my car AKA the million dollar marauder as my coworkers call it lol.
  14. #44
    Jun 2012
    New jersey
    did those yukon Spider gears work. i'm in the same predicament. just failed with the mustang 8.8 gears
  15. #45
    Aug 2018
    Quote Originally Posted by Cygnus View Post
    You have to buy the mustang carrier. They do not make spider gears for the marauder not even aftermarket. Why the marauder has specific carrier is beyond me.
  1. For Sale For sale 2004 silver maurader
    By Brett in forum Marauders for Sale
    Last Post: 07-13-2019, 06:50 PM
  2. 410 gears
    By kashvili in forum Shop Talk
    Last Post: 05-21-2004, 05:41 PM
  3. Marauder vs. Maserati Spider
    Last Post: 12-12-2002, 10:27 AM
  4. Gears
    By JFB in forum Community Discussion
    Last Post: 08-30-2002, 10:29 AM
  5. Gears.....How much?!
    By Romo53 in forum Community Discussion
    Last Post: 08-16-2002, 06:01 PM
