Page 4 of 4 FirstFirst 1234
Results 46 to 55 of 55
Thread: 03 maurader spider gears?
  1. #46
    Aug 2018
    Somersworth New Hampshire
    Quote Originally Posted by Cygnus View Post
    did those yukon Spider gears work. i'm in the same predicament. just failed with the mustang 8.8 gears
    Contact mustangeddie. I believe he has a couple carriers laying around.
    03 black 300A # 2827 stock setup 275,000 on car. 65,000 on engine from a 04. 03 engine died at 273,000 . Rear cat delete with magnaflow 11256 mufflers.
  2. #47
    Nov 2017
    Blue Springs Missouri
    Did you buy a gear install kit? If so which one did you buy?
  3. #48
    Aug 2018
    Quote Originally Posted by Blakshukvw View Post
    The carrier I got from mustangeddie had a set of gears. It was a used unit I just replaced the clutches. I used the Yukon clutches from summit racing.
  4. #49
    Aug 2018
    Gears are from 98 to 2004 if I remember correctly. But if not someone please correct me if I'm wrong.
  5. #50
    Nov 2017
    Gear install kits come with the pinion and carrier bearings as well as wheel bearings and all seals. Did you not install new bearings? New s spring? Seals?
  6. #51
    Washington State
    See items #16:
    Second one is "ALL MODELS; W/TRACTION LOCK"
    https://parts.autonationfordwhitebea...--differential
  7. #52
    Aug 2018
    Quote Originally Posted by NXSBOB View Post
    See items #16:
    Will not work...been there done that. Ford told me all spider gears have been out of production. No other gear that I've found or Ford will fit the marauder. For some reason its carrier is specific to that vehicle only. I went round and round with Ford and the auto part stores. The gears are entirely shaped different.
  8. #53
    Aug 2018
    New axles and seals and axle bearings. I Used the used spider gears carrier and bearings on carrier. Replaced clutches and shims. Had to get the car off the lift so time was a issue. Will be replacing gears and bearings soon.
  9. #54
    Dec 2018
    Albemarle,NC
    Quote Originally Posted by Maverick pro View Post
    Yep you are correct all 8.8 spider gears from those years are the same except for the 03-04 Marauders.
  10. #55
    Aug 2018
    Quote Originally Posted by mustangeddie View Post
    Thank you mustangddie!
  1. For Sale For sale 2004 silver maurader
    By Brett in forum Marauders for Sale
    Last Post: 07-13-2019, 06:50 PM
  2. 410 gears
    By kashvili in forum Shop Talk
    Last Post: 05-21-2004, 05:41 PM
  3. Marauder vs. Maserati Spider
    Last Post: 12-12-2002, 10:27 AM
  4. Gears
    By JFB in forum Community Discussion
    Last Post: 08-30-2002, 10:29 AM
  5. Gears.....How much?!
    By Romo53 in forum Community Discussion
    Last Post: 08-16-2002, 06:01 PM
