Results 1 to 15 of 18
Thread: rear air suspension issue sanity check
    Mar 2006
    LKN, NC
    Angry rear air suspension issue sanity check
    So my "AIR SUSP" light came on today and the car has the gangster lean going on. I went out and cycled the ignition and the compressor kicked on as intended. But then I immediately started hearing a hisssssssssssssing noise coming from the back of the car.
    I'm guessing an air spring has gone bad? Seems like the most obvious explanation given the symptoms.
    R.I.P. SC Cheesehead. You were a good man and I am honored to have known you.
    Air spring, or solenoid didn't close would be the first two things to check
    Mar 2006
    LKN, NC
    I'm going under the car after lunch with a spray bottle of soapy water.
    I've read that the Arnott compressor is the best replacement for that part, but what about Arnott spings? Are those the go-to replacement (if it turns out I need to replace the springs)?
    Jul 2014
    NY
    Arnott and Suncore are both reputable brands:
    https://www.amazon.com/Suncore-40F-1...rcury+Marauder
    Mar 2006
    LKN, NC
    Symptom:
    WELL THERE'S YOUR PROBLEM!
    Bubbles!
    And it's crazy dry-rotted down there too.
    Let's see how fast I can get two springs from RockAuto.
    Jul 2003
    Yonkers NY
    Also ford still sells oem air springs.
    Charlotte, N.C.
    Quote Originally Posted by vonirkinshtine View Post
    Symptom:
    Bubbles!
    Ah crap man!! That is terrible---I thought those cars had springs--you mean they have air bags like the Marauder/Didn't realize
    12.45 at 109.6 MPH
    1.92 Sec .- 60 '
    Alt .SSHS 9 --11/7/09
    '06 CV P71 Street Pkg
    Interior Marauder Floor Shift
    All New Parts
    In Memoriam....11-14-13
    Lehigh Valley, PA
    Quote Originally Posted by Marauderman View Post
    HPP's and Sports had air ride, the air ride was not created for the Marauder. Sports got base spring rate airbags while HPP/Marauders had a "sportier" stiffer spring rate.
    OP I put OEM airbags in my 03 Marauder a couple years back, mine were dry rotted after 150k+ miles but still held air. I think it was member lifespeed who swapped to a set of aftermarket "limo" bags and found the ride got a lot harsher.
    2063/3214
    5377/7838
    Nov 2012
    Sacramento
    Yes, see my post under suspension. Code number is there. Limo bags have aluminum collars vs plastic collars and appear much meatier, thicker, sturdy. They are a little more bouncy on the roughest roads... But other than that they are amazing.
    Mar 2006
    LKN, NC
    C'mon Tom! We even talked about that when you first brought the car over for me to check out. I heard the compressor running when you turned the car off. Hahahaha.
    Yeah, it has the same rear air setup as the Marauder.
    I ordered the Arnott "Limo" springs. They had me at "aluminum piston". I plan on adding a trailer hitch so I thought these "heavy duty" springs were the way to go. Thanks for the warning about the ride quality. From what I remember the spring rate (or the "feel" I guess we could call it) is about on-par with the P71 suspension. Those cars are pretty stiff.
    I have the springs from Rock Auto. I'll be installing them this evening. Will update once done.
    Mar 2006
    LKN, NC
    Update:
    Got the air bags changed out tonight (both sides because why not). Passenger side was definitely worse off though.
    These are the new Arnott A2220 (left) compared to the blown OEM spring (right)
    It was actually incredibly easy to replace the springs! Once the car was on jack stands it only took me about 45min to do both sides.
    BUT NOW THE COMPRESSOR WON'T KICK ON!
    I checked the fuse and relay. Not the issue. I'll dig into it tomorrow. Fortunately I don't have anything else going on tomorrow.
    Mar 2006
    LKN, NC
    Can anyone confirm if there is, in fact, a separate Data Link Connector (DLC) for the Air Suspension Module? The workshop manual says there is. And my OBDII reader isn't finding ANY parameters for the RAS through the connector under the steering wheel.
    Compressor still isn't kicking on and I would love to grab a DTC. But I can't communicate with the right channel.
    Mar 2006
    LKN, NC
    Now I'm stumped.
    I jumpered pins 30 and 87 on the air suspension relay (number 303) and nothing happened. Then I took the compressor out and put it on my workbench. I put 12V to it there and it worked.
    Somehow my compressor is not being told to kick on. I feel like the master switch in the trunk is off, but it is most definitely on.
    I still would like to pull the DTCs if I can figure out how to read them.
    Mar 2006
    LKN, NC
    Also, these are very helpful.
    dRock96Marquis over at CrownVic.net put together this very comprehensive description of the RAS system.
    https://www.crownvic.net/drock96marquis/RAS.htm
    And in his article he references this article from LincolnsOnline.com
    http://www.lincolnsonline.com/tech/00061.html
    Mar 2006
    LKN, NC
    FINAL UPDATE: I'm an idiot.
    I gave up on Sunday and took the car to the shop. They called me Tuesday (which was the earliest they could get it in) and said "It's fixed! You're all set!"
    Sooo...apparently when I was replacing the springs I accidentally unplugged something (either a solenoid or the height sensor, they didn't say which). They found it, plugged it back in, and everything works just fine.
    *sigh* at least it was a cheap fix, haha.
    P.S. I love the Arnott A2220 springs I haven't noticed a harsher ride at all!
  1. KB Front suspension Issue
    By John F. Russo in forum Steering, Suspension & Brakes
    Last Post: 01-15-2009, 01:54 PM
  2. Air ride compressor sanity check
    By Go Mifuni in forum Shop Talk
    Last Post: 08-10-2007, 11:47 AM
  3. Air suspension issue
    Last Post: 08-02-2007, 06:35 AM
  4. Check Engine Light Issue
    By Bluerauder in forum The Lounge
    Last Post: 05-25-2007, 06:28 AM
  5. Got my Marauder back, air suspension issue?
    By Fourth Horseman in forum Shop Talk
    Last Post: 01-05-2004, 09:22 AM
