I'mtalling Moog upper control arms, there's a 3/16 gap between strut housing and inner control arm bushings. Am I supposed to put the supplied washers in the gap?
______________________________ _______________2003 BLACK 300A 06/19/2002 Build 1665 of 7839
I don’t recall any washers supplied. I do remember having to adjust the bushings in my press to line up correctly.
Mine came with the washers and it said to use them in the installation. If not you will have the gaps.
03 black 300A # 2827 stock setup 275,000 on car. 65,000 on engine from a 04. 03 engine died at 273,000 . Rear cat delete with magnaflow 11256 mufflers.
I ended up using press to push the bushings in to match removed control arm.
There should be spacers included. I’ve installed at least 4 sets.
2003 DBP/LF - # 36 (sold)
2003 DBP/LF - # 205 (sold)
2004 Black - Trilogy #43
2003 Black - shitbox (sold)
2004 DTR - shitbox #2
