What’s everyone using and what’s the best place to purchase them? I purchased the cables a few years ago. Now I want to do this. I just need the proper terminals
Which terminals?
You can use these:
https://www.ebay.com/itm/2PCS-Car-Ba...EAAOSwfrhdVBYM
or these:
https://www.ebay.com/itm/Car-Silver-...sAAOSwHu5b9ocj
or these:
https://www.ebay.com/itm/A4A-Us-Ship...IAAOSw0fhXmX12
Any terminals will do just make sure they're pure copper not coated
Do you all run a positive wire to the fuse panel in the engine bay as well? I’ll have a starter wire, alternator wire, and my amp in the trunk.
There will be 3 wires going to the stud on the engine bay fuse / relay box.
Battery to fuse / relay box
Fuse / relay box to alternator
Fuse / relay box to starter
You also might want to think about a fusible link(s) or fuse in the wire from the fuse / relay box to alternator.
I found all the wires coming off the fuse box to be not so tidy. Plus with having it mounted facing the core support and only an inch or so gap, there simply wasn’t any room on that stud.
I chose to mount a distribution block down low behind the headlight (where a stock battery would sit). I ran the battery wire to that then branched off from there to the fuse box, trunk feed to the trunk distribution block (amps and fuel pumps), starter, and Alt. I over fused with one on the battery cable pre distribution block, one going off to the Alt, and a third going off to the trunk. 200 amp IIRC for the first two, and I think 100 towards trunk.
I would be very careful with the battery junction fuse box when loosening the nut. There’s 2 buss bars that are inside the fuse box. My top buss bar broke right off. I had no choice but to solder. I bought a Crown Vic pi 2009 fuse box and opened the inside to do some more research.
This is not easy job removing those buss bars off the fuse box. I got 1 off but it’s not the top buss bar I needed. The top looks like hell to remove and prolly won’t be removable without damaging the box. Here’s some pics of what it looks like. The circle in red is also where the black piece broke off. I’ve been feeling like crap since it happened a month ago. I haven’t noticed no power loss or voltage issues. Nothing has been acting up. Put about 700 miles and it’s been a month.
I just know if i have to replace the whole fuse box that’s gonna be hell and back dealing with all those wires. I’m scared
300A 8-20-02 #3849
Webasto Aftermarket Moonroof
Rear Spoiler
S55 Tail Light Treatment
5% Limo Tints
Fresh Black Paint & PVD Chrome
Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
Terminals and grounds
Positive running toward distribution block
Distribution block
fuse box out at 9 o’clock
Trunk harness out at 11 o’clock
Alt out at 12 o’clock
Starter out at 3 o’clock
Main positive in at 6 o’clock
Alt wire
Alt wire continued
Added a 200 amp Alt with this wiring and this car has never had this much juice since I bought it in ‘04!
I can actually listen to music with two amps with the A/C on at night running all lights while driving twin fuel pumps and a hurricane sounding aftermarket radiator fan. Not too mention turning the two additional blower cog pulleys and two manual tensioners.
And who would have thought the Marauder lights were more than glorified coach candle lights?? They are actually BRIGHT now!
Hey Bob I’m not sure but where is the ground running to in the circle I highlighted in red ? It should be runnin to your engine block ground. Everything looks good. Also on the fuse to alternator it’s recommended 250 amp fuse but 200 is safe.
300A 8-20-02 #3849
Rear Spoiler
5% Limo Tints
