Results 1 to 12 of 12
Thread: Power Door lock Switch L/S
    Long Island, NY
    The door lock on the left front door only opens and doesn't lock with the switch or remote.
    All other door locks work as they should.
    I don't hear any sound when in L/f door when the remote or switch is activated to lock, it opens with remote or switch.
    Any help would be appreciated.
    Thanks,
    John
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    May 2009
    Moreau Island
    Probably a bad solder joint. Re-solder or replace the switch.
    Long Island, NY
    I ordered a new switch.
    Thanks
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
    Feb 2018
    Saudi Arabia
    I don't think it's from switch, because if so it will lock with the remote
    I think you can try to reprogram the remote control to the car maybe it will work, let us know how it goes if you fixed it.
    Sent from my ONEPLUS A6013 using Tapatalk
    Long Island, NY
    I doesn't lock with the door switch or remote either.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
    Lehigh Valley, PA
    either you have a wiring problem or your lock actuator is crapping it. You can confirm it's not the switch by swapping them side to side noting that the problem remains.
    2063/3214
    5377/7838
    Feb 2017
    New Orleans, LA
    usually the rivet breaks loose on the door for the actuator. With the door open you should see a rivet in the middle of the door down low. If its not there or loose then thats probably your problem.
    Long Island, NY
    Replaced the rivet prior to the current problem.
    There is no movement or noise when attempting to lock. All others door locks are working as they should.
    The only problem is the locking of the drivers door. It works fine with key fob or door switch to open.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
    Jul 2014
    NY
    I just encountered a similar, or the same problem. The door will not unlock or lock with the key fob, but the door will unlock with the actual key in the lock. Every time I attempt to lock it with the key fob, I hear something loose moving within the door. Is that door lock actuator or something else entirely?
    I also found this link which I thought was helpful:
    https://www.youtube.com/watch?v=Ndo9Gx04eJk
    Sep 2006
    Psych ward
    Quote Originally Posted by jgc61sr2002 View Post
    You ever find out what the issue was????
    • 82 GT coyote swap started
    Long Island, NY
    Purchased a new assembly.
    At this time the locks are working as the should.
    Thanks
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    2012 Kia Sedona Van
    Member # 440
    ----- John
    Jun 2006
    Central New Jersey
    Thanks for finding this. I wasn't sure how to do this without using a rivet tool that I don't have.
    Build Date 3/19/04
    Adopted on 10/19/07
    Seq#2102 of 3214
    #681 of 997 SBs
    #154 of 336 SBs with the moonroof
    Thanks Brian
    Member of The 100K Club 11/20/11
    Options-
    moonroof-heated seats-6-disc changer-trunk organizer-rear spoiler-mercury all weather mats
    Mods-Extras-Bling-
    Action Automotive-SS Inserts
    Auto Meter 4327 Oil Pressure Gauge
    Badgeless Grille(Thanks 03 Merc)
    Big Mike's Performance-"Sto n Sho" License Plate Holder
    Dead Pedal(Thanks lji372)
    Curless's Pedal Gear Repair
    Cruzer's-Arm Rest
    EATC Ungrade(Thanks JACook)
    Escape/Audiophile Radio Upgrade(Thanks shodude)
    Ford Racing M-7195-AOD Aluminum Trans Pan
    Innovative Interceptors-God's Head Valve Stem Covers
    J-Mod Valve Body
    K&N Performance Intake Kit{CAI}
    LCM Upgrade(Thanks Fastblackmerc)
    Marty-O Fender Badges, Tune & 4:10s
    Panther Lights HID Headlights
    Pro-gard Skid Plate
    Rear Cooling Head Mod
    Visteon Sirius Satellite Radio Setup(Thanks RoyLita)
    Weather Tech-Side Window Deflectors
  1. Power door lock Bermuda Triangle
    By Gixerdevil in forum Interior Electrical/Electronics
    Last Post: 05-10-2013, 05:15 AM
  2. driver door lock/unlock switch
    By ncmm in forum Shop Talk
    Last Post: 07-10-2012, 03:46 PM
  3. Replies: 8
    Last Post: 07-31-2011, 06:51 PM
  4. problem with drivers door power lock
    By ezratty in forum Community Discussion
    Last Post: 09-06-2007, 08:48 PM
  5. Power door lock sticking in cold weather
    By stevenp1 in forum Shop Talk
    Last Post: 01-22-2005, 02:43 PM
