Results 1 to 8 of 8
Thread: passenger head light low beam inop High beam works
    Sep 2005
    APPLE VALLEY,CA
    My Passenger headlight, low beam will not work. High Beam does work.
    I replaced the bulb, tried a new headlight, and replaced the LCM (with my extra).
    None worked. Any suggestions?
    Bad headlamp socket, bad wiring, did you check for voltage at the socket with a dvom?
    Trilogy # 192 / T.S. 0012
    Sep 2005
    APPLE VALLEY,CA
    No, I wouldn't know what to do. Why would High beam work, and not low beam?
    Trying to figure something like this out over the internet without any type of diagnostics will be impossible. I'll guess your new bulb is bad? Maybe a rodent chewed a wire in half, maybe the connector is bad on the low beam circuit. There are a lot of possibilities, without knowing if voltage is present and how much voltage, it makes it very difficult to determine the actual cause.
    Lehigh Valley, PA
    because the high and low beam do not share power, only ground, hence why the 9004/9007 socket has 3 wires. One for high beam, one for low beam, one for ground. When you flip from low to high it powers a different filament inside the bulb.
    You're going to probably have to probe wires with a voltmeter and start tracing things back. To rule out the harness that goes from the headlight bulb to the car, you can swap that from side to side and see if the problem follows.
    I could be wrong on this but I swear each low beam has its own fuse, I remember dealing with this when I did my projector retrofit and popped a fuse. Check the owners manual on that one.
    2063/3214
    5377/7838
    Wisconsin
    Correct. Passenger compartment fuse panel.
    #24 10amp left hand (driver side) low beam
    #26 10amp right hand (passenger side) low beam
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Sep 2005
    APPLE VALLEY,CA
    The correct answer was: check the fuse.
    #26 10amp right hand (passenger side) low beam was fried out.
    replaced. Works great.
    Could have swapped lights left to right to make sure it was not a headlight harness issue. Been there.
    The manual does help to find fuses, glad you found the issue without tools..
    Now to find the power to ground issue that blew the fuse
  1. No right turn flash when on low beam
    By HITEKBALANCER in forum Interior Electrical/Electronics
    Last Post: 06-10-2013, 06:24 AM
  2. H/L beam lights
    Last Post: 12-22-2011, 07:29 AM
  3. high beam question
    By dankwun in forum Shop Talk
    Last Post: 06-24-2010, 11:26 AM
  4. high beam trouble
    By airborne_mp84 in forum Shop Talk
    Last Post: 06-03-2009, 02:24 PM
  5. No low beam???? **HELP!!**
    By OneBADLsE in forum Shop Talk
    Last Post: 10-19-2007, 06:23 AM
