Results 1 to 15 of 30
Thread: ABS Light Came on
    Jul 2010
    Crook County
    ABS Light Came on
    Drove the car a bit more since I replaced the trans range sensor part # sw5214. After about a couple days no trans codes got thrown. Fast forward today my ABS light came on. Plug in the xcal4 and no codes. Hmm thats strange.. anyways my local mechanic said to bring it in and scan it on his scanner since my xcal4 won’t read it cause it’s not an obd2 code.
    Also I do have to remind you guys if it can be the battery junction fuse box messing with it ? I had mentioned in my last few posts about my battery junction box top buss bar terminal breaking off and having to solder. Anybody ever replaced their fuse box successfully on the MM ?
    300A 8-20-02 #3849
    Webasto Aftermarket Moonroof
    Rear Spoiler
    S55 Tail Light Treatment
    5% Limo Tints
    Fresh Black Paint & PVD Chrome
    Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
    Wisconsin
    Check the rear wheel speed sensors, they like to back themselves out.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Lehigh Valley, PA
    ABS codes are not able to be read by basic OBDII readers, your mechanic is correct. Just have him scan it and see whats up, I had to do both front wheel hubs on my 03 from the sensors going out.
    2063/3214
    5377/7838
    Jul 2010
    Crook County
    Thanks guys. The scanner is pointing towards the rear driver side wheel sensor.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Jul 2010
    Crook County
    ABS Light Came on
    After looking at the car on the lift it looks like both rear abs wheel sensor are shot. Pinion seal is leaking. The axle seals look like they should be replaced also. Will get all the parts ordered today. I just can’t figure if I have to order the whole m-2410c kit again or can I just buy the axle seals separate. Any help is appreciated thanks.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Jul 2010
    Crook County
    ABS Light Came on
    Anybody know the correct part # for the pinion flange ? My Ford dealer is giving me 2 different part #s which are
    dl3z-4851a
    4L5Z-4866-AA
    Reason why I ask because my pinion seal keeps leaking everytime I replace it. Ive replaced it 2-3 times in the past 7 years. I also have the dynotech D/S
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Jun 2008
    Waukesha, WI
    I've used repair sleeves with success if you want to go that route?
    Jul 2010
    Crook County
    ABS Light Came on
    Ok I got the right part number looks like dl3z4851a is the pinion flange. ABS sensors came in today got them both for a killer price 160 for both when retail is 135 for each. (Got a friend with a body shop that has a discount).
    Last is the axle seals and pinion seal. Which im gona order directly from Ford. Also instead of getting the M4210C Master gear kit, From what I’m told, the axle seals from Ford are better than the Ford Racing Kit. Royal Purple 75-140 gear oil and Lubelocker FLR-880 gasket is coming in tommorrow.
    Will take it straight to the man who rebuilt my rear end Hans at Deans Performance.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    May 2009
    Moreau Island
    First thing I've ever seen made in Romania..... besides gymnasts.
    And massage “therapist’s”..
    Jul 2010
    Crook County
    I hope those abs sensors don’t have any gypsy curses cause I had a gypsy curse spell put on me by my ex.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Sep 2015
    Mississippi
    And AK-47’s
    Oct 2014
    Cunningham, Kansas
    DL3Z-4851-A is the pinion flange you want. I work in the parts dept. at a Ford dealership. The "4866" is the part that connects the "4851" flange mounted to the pinion gear to the driveshaft.
    Jul 2010
    Crook County
    Quote Originally Posted by Fastbob View Post
    Correct the 4866 is the driveshaft flange that connects to the 4851 pinion flange. I even drove out to my local Ford dealer and harassed the parts guy which is the right part #. Luckily he was nice and printed me out a sheet
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
    Jun 2007
    Whitehall, PA
    Ford racing sells the pinion flange. Part #: M-4851-B
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
  1. Head light and tail light resources
    By MinnesotaMM in forum Shop Talk
    Last Post: 09-17-2012, 04:05 PM
  2. E-Brake Light coming on (not ABS light)
    By rickey1987 in forum Shop Talk
    Last Post: 12-23-2009, 10:42 AM
  3. Blinking o/d light and battery light
    By SID210SA in forum Transmissions
    Last Post: 11-26-2008, 12:19 PM
  4. Gauge light & heated seat light inop
    By airborne_mp84 in forum Shop Talk
    Last Post: 01-04-2008, 09:59 PM
  5. O/d Light Blinks, Followed By Check Engine Light
    By jerrykoziol in forum Community Discussion
    Last Post: 11-12-2006, 07:15 PM
