Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: ABS Light Came on
  1. #16
    Jul 2010
    Crook County
    ABS Light Came on
    Ford racing sells the pinion flange. Part #: M-4851-B
    Hmm I might get that one, if it’s better quality
    300A 8-20-02 #3849
    Webasto Aftermarket Moonroof
    Rear Spoiler
    S55 Tail Light Treatment
    5% Limo Tints
    Fresh Black Paint & PVD Chrome
    Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
  2. #17
    Jul 2010
    Crook County
    ABS Light Came on
    Update
    I took the car to my local Mechanic to do the install. Once he opened the rear end cover, he noticed the carrier shims were out of place and backed up or either ripped. Also metal shavings were visible from the carrier shims. It seemed like the TA Girdle Rear End cover helped so the carriers shims wouldn’t make contact with the TA pan.
    The kit I used was the m4210c3 Ford Racing Master Gear Kit. I never heard no noise or felt anything strange in the rear end. Now it makes me wonder how long i had been driving with this issue.
    My Rear end was rebuilt back in 2012 at 110k miles. Now the Car is at 193k and this is the first time it’s been opened. Royal Purple Gear Oil 75-90 Gear Oil was used by Han when he rebuilt my rear end in 2012. I also had new 31 Spline Ford Axles, 31 Cobra Carrier with CF Cluths. 410 Ford Racing Gears, m4210c3 Master Kit and TA Girdle and stud kit.
    My local mechanic said im very lucky the ABS light came on so I can check the rear end and that my rear end didn’t explode. We put the cover back on and filled the gear oil. I limped it back home because I don’t have the right shims available and it would take a week for the parts to get here.
    I guess now my biggest concern is if my axle shafts are toast. My axle shaft seals didn’t leak. Reason why I wanted to change them was just for extra security. It’s just my pinion seal that’s visible with the leak.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  3. #18
    It’s not at all uncommon to see the spacers move. Same goes for chewed up spider gears and leaky pinion seals. These rear ends don’t seem to last at all.
  4. #19
    Wisconsin
    Quote Originally Posted by Chi Stallion View Post
    Update
    Get rid of the shim packs & replace with 1-piece solid shims.
    Same thing happened to Joe's DTR a while back.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  5. #20
    Jul 2010
    Crook County
    Do you know the part # I should get
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  6. #21
    Wisconsin
    Get the exact measurement if each shimpack thickness.
    Go to Ford parts and get the 2 solid shims you need.
    If they do diff work they'll stock an assortment.
    I had to order 1 of the 2 I needed.
    Install & measure backlash.
    If off, get the 2 shims needed to shift the carrier the required amount.
    Ford has a chart somewhere (I can't find my copy) that tells you the shims required to make the required adjustment left or right to dial in the backlash.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  7. #22
    Jul 2010
    Crook County
    ABS Light Came on
    Update
    Axle shafts got replaced with new Ford 31 Spline, Timken axle bearings and pinion bearings, shims got replaced with 1 piece solid shims. Motorcraft new axle seals and pinion seal. Also the whole rear end was cleaned up before the install so no metal shavings are left. My 4.10 ring and pinion gear was fine also was the 31 spline carrier.
    Big thanks to the Man the Myth the Legend Han @ Deans Performance.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  8. #23
    Jul 2010
    Crook County
    I forgot to mention the abs light is still on with the new abs sensors. Do I need a special scanner to turn it off ?
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  9. #24
    Nov 2017
    Blue Springs Missouri
    My ford tech that’s going to do my 31 spline 4.10 upgrade told me definitely don’t use those shims provided in those kits that they are junk. He also advised against everything ford Motorsport as its not OEM quality. My build consists of everything from the axle seal to axle seal OEM ford including the brand new ford gear set. Furthermore, he told me he would acquire the correct side shims from his parts department.
    OEM bearings are koyo btw.
  10. #25
    Jun 2007
    Whitehall, PA
    If the ABS light is on and there are no codes, or scanners are not able to connect to the ABS system, it is most likely that your ABS module is bad. You can remove it and send it out to be repaired.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
  11. #26
    Nov 2017
    I dunno. Mine has 230k on it and my explorer had 260k on it. Ford 8.8s have been known to be pretty solid rear ends.
  12. #27
    Jul 2010
    Crook County
    ABS Light Came on
    Just a heads up I was trying to remove the abs module earlier and when I removed the jlt cold air intake I noticed the filter cover was rubbing against one of the abs lines. I don’t see any visible leaks but it looks very corrosive and about to crack.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  13. #28
    Oct 2014
    Charlotte, NC
    eeeek! Thanks for this - glad you caught it when you did.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
  14. #29
    Jul 2010
    Crook County
    I really can’t blame nobody but myself. When I installed a new JLT filter back in June, I was a bit bothered by the filter rubbing against the windshield washer reservoir, so I mounted the filter cover on a angle which sat directly on top of the abs brake line. Stupid careless mistake on my end.
    Only positive thing is I caught it before the line cracked and started leaking. I went to my local Ford dealer to harass the parts guy and see if that brake line is in the parts inventory but the parts department was closed. I have a feeling its gona be discontinued.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  15. #30
    Jul 2010
    Crook County
    Update
    Looks like the ABS nightmare is finally coming to an end. After having the abs module sent out and repaired at module repair pro, the light still was on after the repair. So my mechanic checked the wiring connection leading to the driver side rear abs sensor. No connection looks like a wire got pinched somewhere. So looks like running a new wire to the connection is the best option. Glad the nightmare is over.
    300A 8-20-02 #3849
    Rear Spoiler
    5% Limo Tints
  1. Head light and tail light resources
    By MinnesotaMM in forum Shop Talk
    Last Post: 09-17-2012, 04:05 PM
  2. E-Brake Light coming on (not ABS light)
    By rickey1987 in forum Shop Talk
    Last Post: 12-23-2009, 10:42 AM
  3. Blinking o/d light and battery light
    By SID210SA in forum Transmissions
    Last Post: 11-26-2008, 12:19 PM
  4. Gauge light & heated seat light inop
    By airborne_mp84 in forum Shop Talk
    Last Post: 01-04-2008, 09:59 PM
  5. O/d Light Blinks, Followed By Check Engine Light
    By jerrykoziol in forum Community Discussion
    Last Post: 11-12-2006, 07:15 PM
