Results 1 to 12 of 12
Thread: Alternator problem report
    Bossier City, La
    My volt meter was reading lower than usual and the idle was sometimes surging. Symptoms of a bad alternator I'm​ told.
    So my son the Honda mech and new owner of Silverback took the alternator to the shop for a look/see. The tech said the pulley was turning but the alternator was frozen.
    I'll report back on the findings, repair parts and labor cost after I get the alternator back and reinstalled.
    Cheers,
    Apr 2010
    South Florida
    Might as well upgrade it to 200Amp and adjust the tune.
    Daytona Beach
    How does a different or higher output alternator affect or need a tune? I didn't know that!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    Metco Control Arms
    4.10 Gears
    Aeroforce Gauges
    Apr 2010
    South Florida
    Quote Originally Posted by Peace2Peep View Post
    You have to adjust the regulator for the correct charge I believe. I'm not too smart with that yet but I did have My alternator upgraded and My tuner said He would have to adjust it for Me on the tune.
    Jun 2009
    Warsaw, Indiana
    On the stock Marauder alternator I think the voltage regulator is integral with the alternator, and is not adjustable.
    The stock alternator has an overrev-disconnect clutch in the pulley. If that clutch fails you could get the symptoms you described. But in that case your voltmeter would slowly drop to a point where the car wouldn't run at all because the battery would be discharging with nothing coming from the alternator.
    The surging could be an idle air control and/or a throttle position sensor going bad. I just had to replace both of those on my MM.
    Apr 2010
    South Florida
    Quote Originally Posted by SteelQualityMan View Post
    My alternator is not stock and neither is the pulley or regulator. It's all upgraded, with a tune adjustment.
    Pat- you should buy a cigarette lighter plug in digital meter.
    i have a digital volt readout and USB socket assy.
    Stock gauge reads like crap and the digital readout will tell you what your alternator is doing while driving.
    i bought mine off amazon.
    i have a 200 amp alt in my car and no special tune, sometimes it fails to charge at moments, then picks back up...
    AJ what did you adjust? Mine does it at random, I loaned my oem alt to a buddy and swapped in this 200 amp alt that I pulled off one of my parts marauders.. I don't know the history of the car or the alt.. never drove it
    04 DTR totaled, might make into a station wagon Here is how bad it was https://youtu.be/REUxjP1BVpg
    04 Whipple SILVER BIRCH
    03 Silver Birch Light Flint <--- Cannot kill it.
    03 C.V. Sport SILVER FROST daily beater
    Wisconsin
    Cool! https://www.amazon.com/s?k=cigarette...b_sb_ss_i_4_22
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    My tune was never adjusted for my 200 amp. I did the big 3 at the same time and all I can say is WOW what a difference. It never fails to charge either.
    Bossier City, La
    Well, I picked up the repaired alternator and installed it yesterday. Works fine. The shop even painted it a combo of Ford blue, internals, and silver, external, at no additional cost.
    They replaced all the bearings and diodes. Cost was $158.00 plus tax (10% here).
    I'm a happy camper.
    Nov 2009
    Newport Beach, CA
    I am jumping into this discussion because I am looking for new 200 amp alternator recommendations. I have the Eaton swap so my alternator spins backwards, I think. I have heard the police interceptor is a 200 amp unit. Can it be used on the typical eaton swap? Thanks Buck
    Quote Originally Posted by MarauderPU View Post
    No. The cop car is not pulse width modulated... lots of threads on this issue, it will bolt up and randomly not charge
  1. Need a report run
    By russell072009 in forum Community Discussion
    Last Post: 07-21-2011, 07:45 PM
  2. Need Car Fax Report
    By MM2004 in forum The Lounge
    Last Post: 06-02-2009, 07:42 PM
  3. Alternator wires melting problem
    By dankwun in forum Shop Talk
    Last Post: 01-28-2009, 04:25 PM
  4. Car fax report?
    By my_rodder in forum The Lounge
    Last Post: 08-11-2008, 05:08 PM
  5. MV 5 Report
    By cruzer in forum North Texas Marauders
    Last Post: 08-11-2007, 09:50 PM
