Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Overheating question
    Jul 2018
    West Bloomfield, Mi
    So some of you may have seen my post about me buying an 04 silver birch with 75k miles sight unseen from Texas. It was delivered to my home in Michigan a couple weeks ago. Been busy with work and unfortunately my father has been ill so I haven’t had much time to fool with the car or even unsure it and drive it. I only transferred the title obviously
    Anyways I just got in it and drove it around for less than 10 minutes. Going around a few blocks. Only got up to about 40 mph. I noticed the rpm gauge not working but I think it was initially when I got in the car, that’s probably not relevant to my question but I noticed the heat not working and then when I was getting back home the temp gauge was reading hot. I turned the car off and popped the hood and heard some ticking coming from the engine so I think it was in fact overheating. When I first got the car I did the same thing, drove it around a few blocks and noticed the heat took forever to start kicking in hot. It did start blowing hot after about 10 minutes. I’m not sure if I paid attention if the temp gauge got hot or not that time. Also I did the ecu test and everything checked out fine so no stuck blend door motor
    I’m not car expert by any means but does this simply mean that I need to replace my thermostat and problem solved or do I have a more serious problem on my hands? I will check the coolant level tomorrow. By the way I don’t work on cars so if have to have someone change the thermostat. Thanks in advance for any help. I hope I didn’t just take someone else’s problem off their hands
    Lehigh Valley, PA
    It sounds to me like you might be really low on coolant, open the crossover tube and see if you can see coolant inside. When my COT was empty I'd have no heat for a while and the temp would rapidly spike up until the T-stat eventually opened and got things flowing. I think your system is really low.
    If it is, you're going to elevate the front of the car slightly, fill the system, let it run and burp, and keep topping it off. Make sure it gets up to temp but in your case make sure it isn't overheating either. Keep the heat on full blast. Once it levels out and stops taking coolant, let the car sit for a few hours and get completely cold. Repeat the process and make sure it won't take anymore.
    https://reischeperformance.com/refill.html
    2016 Ford Mustang GT PP - Lund nGauge, BMR vertical links
    2003 Mercury Marauder - Stainless Works LT's, Stainless Works 2.5" Catback, JLT Intake, Mo's Xcal4 Tune
    5377/7839
    Jun 2010
    Boston
    I had overheating issues, check that crossover...It most likely needs to be burped as stated above. Good luck.
    Most likely a burp is needed.
    Most owners not aware the coolant system has a burping procedure to fix air trapped. Read this link for steps to do it.
    https://www.mercurymarauder.net/foru...Burp-Procedure
    Jul 2018
    West Bloomfield, Mi
    Thank you guys for the reply’s
    Dumb question but just to confirm, this is the crossover cap correct?
    I don’t know what kind of coolant or mix is already in there. What kind do u guys recommend putting in and also the reservoir seams to be full
    Oct 2014
    Charlotte, NC
    Quote Originally Posted by MotorCity View Post
    So some of you may have seen my post about me buying an 04 silver birch with 75k miles sight unseen from Texas. I hope I didn’t just take someone else’s problem off their hands
    I remember this one - guy's wife drove it to church on sundays?!?! Looked like she bumped into everything in the parking lot. It's fixable unless there's more you aren't telling us. Can't imagine buying a car without putting my hands on it first.
    Current Garage:
    2004 DTR Marauder
    2005 Mustang GT Premium
    2008 Triumph Sprint ST
    2015 Triumph Trophy SE
    Life is 10% what happens to you and 90% how you react to it.
    Charles R. Swindoll
    Oct 2010
    Michigan
    You sir are correct, that is the coolant crossover cap.
    Nov 2006
    Milpitas, CA
    Maybe the previous owner had the thermostat replaced. From my experience, some web sites say the grand marquis thermostat is the same as the Marauder. And that is incorrect. Maybe he had the incorrect thermostat put in. They did that to me and my car kept overheating. The correct Marauder thermostat has to have the bypass.
    1988 LTD Crown Victoria S
    Feb 2017
    New Orleans, LA
    in my experiences its usually the system needs to be burped as well
    It would help if you use an impact to get that cap off at least thats the only way mine was coming off the first time.
    I had to put 2 gallons in mine one day when my reservoir hose came disconnected and I lost some coolant (reservoir was still full too).
    '03 Marauder 300A - 87 Octane Race Tune
    O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
    EFI Calibrator - decipha @ EFIDynoTuning
    http://www.efidynotuning.com/tune.htm
    Jul 2018
    West Bloomfield, Mi
    Thanks again
    I know u can’t diagnose this over the internet but how likely do you guys think this can be a bad head gasket? It overheated in less than 10 minutes
    Are you blowing white smoke out tail pipe?..air pocket prohibits coolant to flow.. overheats very quick. Try the most likely first...
    Jul 2018
    West Bloomfield, Mi
    No white smoke out the tail pipe. Guess I’m thinking the worst.
    Lehigh Valley, PA
    You are, it really most likely is just the system being low.
    These cars take Motorcraft Gold (Zerex G05 50/50 mix is perfectly fine) from the factory.
    5377/7839
    Jul 2018
    West Bloomfield, Mi
    I just looked in the crossover tube and see no coolant at all.
    In the end, should the crossover tube be full to the cap?
  1. Overheating Question
    By DarthMarauder in forum Shop Talk
    Last Post: 01-28-2010, 05:18 PM
  2. Overheating...
    By maraudermetz in forum Shop Talk
    Last Post: 07-04-2008, 06:49 PM
  3. overheating
    By screamdennis in forum Shop Talk
    Last Post: 07-26-2007, 01:29 PM
  4. Why Is My MM Is Overheating ???
    By revereamg in forum Shop Talk
    Last Post: 02-27-2007, 09:45 PM
  5. Overheating
    By arogant in forum Shop Talk
    Last Post: 08-09-2005, 06:36 AM
