Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: are 2003 and 2004 Marauder alternators the same? Interchangable?
  1. #16
    Lehigh Valley, PA
    Hey Ryan, have you checked if the dash light has been removed or isn’t blown? All I’ve ever read is it may work but the light won’t shut off?
    I promise my battery light does work and its not illuminated. I was having problems with reman alternators (from fords) where when the car went under load, voltage would tank to mid 12 volts. At cruise or even WOT it'd be fine. After 2 reman alternators with this problem, I threw on a 78,000 mile OEM 4G alternator from my friends totaled 04 sport and it completely fixed my problem.
    Just to add to that, my friend who gave me the alternator had it on his trilogy marauder briefly with no charging issues either, I also know the battery light worked in that car because it was flickering on/off due to a pigtail issue a year prior.
    The difference is the clutched pully.
    On the MM at WOT the PCM shuts the alternator off to gain a few ponies. (Less drag)
    The CV alternator wont have this feature.
    The clutch can easily be swapped (which I did) and both alternators are PCM controlled, so why would the civilian vics lack this feature?
    I'm also pretty sure some tuners disabled that feature, at least I remember Lidio saying he did so voltage would stay more consistent especially on trilogy cars.
    2063/3214
    5377/7838
  2. #17
    I call bullsheep. The Vic alt won’t work, many people buy a Vic alt and it won’t charge... there have been wayyyy too many posts about it. Been a lot of folks handed a 4g Vic one by the parts store and they don’t work.
    I am not discrediting anyone, but I really don’t feel like arguing when I’ve seen it in person.
    plus the brush packs are completely different colors, making me believe one is pwm and the Vic being 5 volts reference
  3. #18
    The Dirty South
    MM is the only panther with this feature from the factory.
    BTW: I didn't run a clutched pulley with either my Trilogy or my current TVS (Because you can't)
  4. #19
    Jun 2015
    O'Hare IL
    I think the police interceptor also has the clutched pulley I think.
    Now it sucks and I dont know what to buy lol.
    I think I'll just have this rebuilt.
  5. #20
    Lehigh Valley, PA
    Running a 98 - 02 (may) be a problem, I've never tried it. People on this site also swear up and down that you can't get "Marauder specific" shocks from Ford anymore which is also absolute ********. If I've learned one thing from being on this site so many years its to do your own research and verify your findings.
    Also it wasn't the brush pack that had a color difference, it was the regulator. Again, I can't speak for the 2002 and older model year cars, but the 03+ panthers all have PCM controlled regulators. This is right from the Ford wiring & electrical troubleshooting service manual for MY 2005
    The PCM determines the optimal voltage setpoint for the charging system and communicates this information to the voltage regulator. It has two unidirectional communication lines between the PCM and the generator/regulator. Lines are pulse-width modulated. (GEN COM) line communicates the desired setpoint from the PCM to the voltage regulator and the generator monitor (GEN MON) line communicates the generator load and error conditions to the PCM. The third pin on the voltage regulator, the A circuit pin, is a dedicated battery voltage sense line.
    I promise you I have absolutely nothing to gain going on MM.net and telling people I'm running a crown vic alternator just for fun. It took me months to rectify that very annoying voltage drop issue, I ended up buying a used marauder alternator off ebay which turned out to be absolute junk. That was alt # 3 after the two remans, alt # 4 was the unit off my friends long totaled sport and its still on the car 20,000 miles later.
    Quote Originally Posted by GoldPanther View Post
    They do but thats usually a 6G alternator, something I wanted to try fitting to my eaton swapped car but its long down the list of projects to tinker with.
    2063/3214
    5377/7838
  6. #21
    Right where you plug it in. See photo
  7. #22
    Nov 2017
    Buffalo, NY
    I had an alternator off an 04 Vic on my 03 trilogy for quite a while, worked perfectly fine.
    Trilogy, kooks, 2.5" exhaust, 4.10's, 31 spline, widened rear's, metco's, addco's, ridetech's
  8. #23
    The Dirty South
    Quote Originally Posted by 77pantera View Post
    Trilogy and Eaton swapped MM alt are exempt as neither use the clutched pulley.
    You cannot utilize a clutched pulley on an alt that spins un reverse.
  9. #24
    Wisconsin
    According to Tasca Ford parts catalogue, the 2003 Mercury Marauder, 2003 Mercury GM and the 2003 Ford CV all use the same part number 4U2Z-10V346-ABRM 130amp alternator or 3W3Z-10V346-ACRM 120amp alt.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  10. #25
    Lehigh Valley, PA
    okay but you can remove the clutch pulley and its the same alternator. Its not like the Marauder has a one direction only alternator, my eaton swapped DTR is using the factory alt with the clutch pulley removed.
    2063/3214
    5377/7838
  11. #26
    Nov 2017
    Buffalo, NY
    It's almost like you can swap pulley's or something.
    The PCM doesn't care which pulley is on there.
    Again, I used an 04 Crown Vic alt, on a 300a, without any issues what so ever.
  1. Which year Marauder to purchase-2003 or 2004?
    By Geewez in forum Welcome Forum
    Last Post: 09-12-2012, 04:33 AM
  2. Wanted To Buy 2003/2004 Marauder in Kansas City
    By 2l8Iwin in forum Marauder Wanted
    Last Post: 08-29-2012, 06:48 PM
  3. For Sale 2003-2004 Ford Mercury Marauder badge set
    By ctrlraven in forum Marauder-specific Parts for Sale
    Last Post: 08-12-2012, 10:25 AM
  4. Wanted To Buy Looking to buy 2003/2004 Mercury Marauder Oregon/Washington.
    By FF1077 in forum Marauder Wanted
    Last Post: 10-07-2010, 04:56 PM
  5. 2003/2004 Marauder Bra for Sale
    By Jeffs in forum Marauder-specific Parts for Sale
    Last Post: 05-20-2008, 09:06 AM
