Results 1 to 11 of 11
Thread: Oil Burn?
    Oil Burn?
    When I go to change my oil after 6 months I am 2 quarts low. I use Mobil 1 Synthetic and usually have only put around 3K miles during that time. I currently have around 95K on my 2004 Marauder and I am not leaking oil anywhere and have had all the seals replaced less than a year ago. Since I am confident that I am burning this oil should I just change my oil more frequently or just top off any missing oil every month? Also should I be concerned this is happening or is this normal for this car with this amount of age/mileage to do this? I have read that a lot of cars burn 1 quart between oil changes and that is normal. I just want to know what is best practice and what has everyone else experienced withe their marauder? Last I was curious at what mileage has anyone rebuilt or replaced the engine of their marauder and if one option is better than another? Any help or advice on all this is greatly appreciated. Thanks.
    The Dirty South
    Down 2qts of oil per change interval.
    I'd be looking for an engine
    How many quarts do you put in at oil change time?
    Blog Entries
    2
    I change at 3-4,000 miles and never add oil on an S/C OEM engine 95K miles or a Cobra engine 112K miles.
    6 quarts were put in.
    I change it once a year anymore with around 1,000 miles of heavy footed city driving and lose nothing at all.
    Still clean as new when I change it and my internals are bright and shiny.
    If you ever pull your timing cover or cam covers you’ll see exactly how it was treated.
    Jul 2010
    Crook County
    Check your oil filter adapter gasket for any leaks
    300A 8-20-02 #3849
    Webasto Aftermarket Moonroof
    Rear Spoiler
    S55 Tail Light Treatment
    5% Limo Tints
    Fresh Black Paint & PVD Chrome
    Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
    Sep 2005
    APPLE VALLEY,CA
    My 244,000 Marauder will use a quart every 1000-1500 miles.
    TALALA OK.
    These engines do not burn oil even high mile ones so yours has a problem of some sort but may still run a lot farther just burn oil only time / miles will tell. Running it two quarts low is not good so you need to add as needed, also if you are using 5w20 you could go to 5w30 or 10w30. This may reduce the burning but won't fix the problem. On the rare chance the PCV valve is drawing to much changing is not expensive and worth doing other than that just drive it and keep it full of oil.
    04 DTR 42K M.
    03 BLK 9K M.
    07 GT500 10K M.
    98 MARK VIII 70K M. BOUGHT NEW
    21 EXPLORER PLATINUM 3.0
    18 GENESIS G80 5.0
    78 RANCHERO 5.0
    54 GMC
    Nov 2015
    NY
    193,000+ Only put on about 2,000 for the summer months with no oil burn.
    Sent from my SM-G930V using Tapatalk
    They burn oil, check it every Friday morning and top off as needed.
    i use 1/2 5-20 and 1/2 10-30 oils on my higher mileage motors
  1. 1k to burn
    By bigmerc281 in forum The Lounge
    Last Post: 03-01-2012, 09:29 AM
  2. Someone please burn my eyes out!
    Last Post: 11-12-2007, 04:53 PM
  3. Burn out.
    By NOPDME in forum Community Discussion
    Last Post: 06-07-2007, 09:16 PM
  4. If this don't burn your can...
    By 2003_MM_FYRE49 in forum Community Discussion
    Last Post: 12-11-2006, 04:24 PM
  5. ...serious burn out!
    By Petrograde in forum The Lounge
    Last Post: 03-03-2005, 09:25 AM
