Results 1 to 8 of 8
Thread: Rough Idle - Slow Start - P0316 and P0306
    Dec 2017
    Ellicott City, MD
    So the title says it all. It has been running rough at idle but runs like a champ otherwise. It is also taking much longer to start sometimes. Doesn't seem to be related to being cold or not. The code reader at one time said cylinder 6. But not now it doesn't say which cylinder. Could it really be just a coil pack?
    Jul 2010
    Crook County
    Get the oem coil and change the plugs. Make sure gapped properly. Also would be a good time to clean your IAC and MAF
    300A 8-20-02 #3849
    Webasto Aftermarket Moonroof
    Rear Spoiler
    S55 Tail Light Treatment
    5% Limo Tints
    Fresh Black Paint & PVD Chrome
    Stainless Works Headers & Full Cat Mandrel Exhaust System w/Magnaflow 11229 Mufflers, Martyo Tune & Coolant Mod, Steeda UDP, Stewart WP, JLT CAI & Catch Can, J-Mod, UHaul Pan, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10, TA Girdle & Stud Kit, Carfixer Alignment & SPC Camber Bolts, Ridetech HQ Front Coilovers w/ADTR extended bracket & ADTR Rear HQ Shocks, Arnott P2936 A/C & A-2220 Bags, Gorilla Lock, Cooper Zeon RS3-G1 Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, SS Brake Lines, AutoMeter Digital Oil & Volt Gauge, Full VLED Interior/Exterior, Alpine ILX-507, PKG-M780 Headrest Monitors, MRP-F300, R-S65C.2 & R-S68 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper DS4 & DSM550 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
    I would do a compression test before purchasing any parts..
    May 2018
    Maryland
    Greg, If you don't have a compression tester I have one and some spare good/used oem coil packs that you can borrow for testing.
    Dec 2017
    Ellicott City, MD
    Hey Boom Boom,
    Are you the one I met over by Casa Mia's
    My motor was rebuilt about 20,000 miles ago by Marty and oil reports are good. I do have a compression tester.
    I think I may have a spare coil not sure. All my tools, etc. are at another house in Maryland
    May 2018
    Maryland
    I'm the one you got the trunk organizer from. Have you looked at the plug yet? That can tell you a lot. If you need a coil, let me know.
    Oct 2014
    Charlotte, NC
    Lightbulb
    +1. I was surprised my low mileage motor had a relatively lower cylinder psi (#4) when replacing spark plugs for the first time not long ago. Still within the 20% limit (150psi vs. 175psi).
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    Aug 2003
    FL
    The long crank time tells me your fuel pressure may be leaking down after you turn the car off and the rough idle with a P0306 seems to point to a leaking injector. Does it smoke at all when you start it?
    Current:
    2004 SB
    Sold:
    17th of 3213 2004 Marauders
    9th DTR of 982
    and best of all,
    71st Trilogy
    2003 TR Mach 1
    2012 RR BOSS 302
    2014 RR GT500
    2003 AB Mach 1
  1. Idle a little rough
    By 88LTDCV351 in forum Shop Talk
    Last Post: 02-12-2012, 05:36 PM
  2. Rough idle
    By walela1 in forum Shop Talk
    Last Post: 07-31-2009, 06:32 AM
  3. Rough / Low Idle
    By arejayesss in forum Shop Talk
    Last Post: 09-26-2007, 05:54 AM
  4. Rough idle and bad MPG
    By Raudermaster in forum Shop Talk
    Last Post: 08-14-2006, 08:22 AM
  5. rough idle, low mileage, slo start
    By fblumberg in forum Shop Talk
    Last Post: 06-10-2004, 07:26 PM
