Any DI engine will have the problem of carbon build up on the backside of the intake valve.
No fuel to wash/clean the deposits off the intake valve.
An oil catch can is a great idea....
but I'm going to solve that problem on my DI TTV6 Fusion Sport the best way possible.... by installing Meth injection.
Heh heh heh.....
