Results 1 to 4 of 4
Thread: help- Small pfft noise when turning steering wheel
    Jul 2003
    Yonkers NY
    I recently dented my oil pan by dropping the car off a floor jack and onto the front left corner of the pan.
    I changed the pan by R&R of the the k-frame with the engine remaining in place. That all seems to have gone well. Some of the PS lines were slightly bent but do not appear crimped.
    When i first started it there was considerable noise that seemed like fluid or bubbles. That cleared itself in about 1 minute. Now the car runs fine and idles quietly. I am finding no fluid leaks or drop in the PS fluid level.
    Here is the symptom. When I first turn the steering wheel in either direction from any resting position there is a short clearly audible "pffft" type noise. Otherwise all seems to operate well and quietly.
    Thoughts?
    Jay
    Feb 2006
    Rosemount, MN
    I wonder if there is a restriction is the lines and the sound you are hearing is the pressure relief valve like when you turn the wheel all the way to one side?
    Jul 2003
    Yonkers NY
    Perhaps. I will try to listen closer. The valve is in the rack?
    Jul 2003
    Yonkers NY
    I forgot to post the resolution to this issue. It fixed itself after winter storage.
  1. Rpm dips when turning steering wheel
    By silversnake in forum Shop Talk
    Last Post: 12-01-2012, 01:28 AM
  2. strange noise when turning key over from glove box area
    By marauder410 in forum Community Discussion
    Last Post: 08-14-2012, 07:26 PM
  3. Steering wheel noise
    By james1986fox in forum Shop Talk
    Last Post: 05-06-2009, 09:57 AM
  4. funny noise when turning sharply to the right.
    By Aren Jay in forum Community Discussion
    Last Post: 08-18-2007, 03:01 PM
  5. loud clicking noise when turning???
    By MercRS in forum Community Discussion
    Last Post: 06-26-2007, 04:48 AM
