Since the car is 16 years old, I'm assuming that a little burning of oil is typical, but does the Marauder eat gaskets like other Fords do?
MaskedMarauder
Current Rides
2016 Ford Edge Sport AWD
- Bronze Fire Metallic with custom pinstriping
- 2.7L EcoBoost Twin Turbo V6
- 21" Rims w/ Michelin Premier LTX 265/40R21 Tires
2003 Marauder 300A Black (Build #1800 out of 7838)
- Order Date: 5/2/2002
- Build Date: 6/21/2002
- First Sale Date: 1/11/2003
- Second Sale Date: 9/9/2019
Options
- With Trunk Organizer
- With Rear Spoiler
- With 6-disc CD Changer
Mods
- K&N Drop-In Air Filter
- JVC KW-M650BT w/ Back-Up Camera and iDataLink Maestro Steering Wheel Interface
- Custom X-Pipe Crossover
- Jones Exhaust Glasspack Mufflers
- Jones Exhaust 3.5" x 22" Polished Stainless Steel Rolled Edge Non-Resonated Exhaust Tips
Former Rides
1990 Ford Tempo GLS
1991 Ford Tempo GL
1996 Ford Explorer XLT
2002 Ford Explorer XLT
2004 Lincoln LS V8
2010 Lincoln MKS EcoBoost
2014 Lincoln MKS EcoBoost
Check the oil filter adapter gasket.
X2 oil filter gasket, and no, they don't. Fords are fine with gaskets. Try a GM 3.1 V6 , Subaru boxer, or Cadillac Northstar! There's your "gasket" cars!
My old 2004 Lincoln LS ate valve cover gaskets almost as often as it ate coils.
MaskedMarauder
Current Rides
Options
- With Rear Spoiler
Mods
Former Rides
1990 Ford Tempo GLS
1991 Ford Tempo GL
2004 Lincoln LS V8
Rear crank seals on fords are notorious too. Usually the crank is so soft where the seal rides it erodes a groove in the crank and then leaks.
2063/3214
5377/7838
Not that bad of a job, takes about an hour. Lots of liquid to handle. main odd tool is a 12mm? "crow's foot" I seem to remember, (which is a truncated open end wrench. Just the wrench part and square hole, handle is cut off/not there.)
