Results 1 to 15 of 22
Thread: Rear Axle Seals
    Nov 2006
    Union City, CA
    Rear Axle Seals
    Well, at 184,000 miles I noticed a puddle behind my driver side rear wheel. My first thought is the rear axle seals. Used to have them replaced constantly on my 88 Crown Vic. Am I only the right track?
    1988 LTD Crown Victoria S
    Apr 2010
    South Florida
    Yes. Replace bearings and seals, inspect axle it could be worn out. Have fun!
    Jan 2018
    Califon NJ
    IIRC, there's a kit with both axles, seals and bearings. I believe it was cheaper than the parts individually. I do not have the part # saved.
    Quote Originally Posted by Grimrepairman View Post
    It even came with friction modifier and gear lube IIRC. Search comes up with this and DANG the price has skyrocketed!!! I paid $295 locally back in like ‘11 if memory serves. Looks like I either have the wrong part number or Ford is REALLY trying to recoup their losses...
    https://www.tascaparts.com/oem-parts...air-3w1z4a109a
    Oct 2003
    Beaufort, SC
    Every year they sit they have to tack on $50.00 inventory cost.........about $500.00 so far maybe??
    I bought mine from a Ford dealer in Charleston that stocked about 50 kits for Cop cars......it was like $229.00 or so......back in the day!!
    Nov 2017
    Blue Springs Missouri
    I believe it’s a good idea to swap to 31 spline axles when replacing the axles for bearing/axle wear because the 28 spline axles were known to be not hardened incorrectly. With the 31 spline upgrade you’ll most likely not have issues for a long long time if ever again. It is usually warn bearing surfaces on the axle that take out the seals.
    Sep 2013
    ST Louis
    Sorry for the derailment but are there any known reports of failed 31 spline axles?
    Sent from my SM-G950U using Tapatalk
    Build# 1979/3214
    Year 2004
    300B
    Ext. DTR
    Int. Dark Char
    FINALLY BOOSTED!!!
    Nov 2017
    I’m sure some can be found but it is well documented the issues with the improper hardening of the 28 spline that lead to their failures, of which proof is highlighted over and over on this website alone.
    Quote Originally Posted by cer0413 View Post
    As far as I know first hand Moser had a bad run over a decade ago. The heating process near the ABS ring caused brittleness and flanges literally snapped clean off the shaft on high HP cars. I witnessed Zack’s prozack black car self destruct at the track. It was a real joy to back it up off the track with like six of us and a floor jack.. A few other reports around the webs came in shortly after of similar situations.
    Oct 2004
    Not all 2003s have bad axles not sure of cut off dates. Maybe someone who knows can chime in.
    Timbuk3, MI
    burt ragio - Not all 2003s have bad axles not sure of cut off dates. Maybe someone who knows can chime in.
    Associated TSB .....
    Oct 2003
    Beaufort, SC
    My 2004 SB car built in November 2003 had bad axles that showed up at 150K miles or so.......I believe ALL of 'em were inferior by design!!
    Nov 2017
    My 04 had 1 bad axle this year. Worn groove on the axle where the bearing rides and bearings looked pretty good otherwise.
    Jun 2008
    Waukesha, WI
    And one of those replacement axles was bad when I pulled them to swap 31-spline axles.
    Oct 2003
    Beaufort, SC
    Was it the right side one Dave??
  1. Dealer will not fix valve seals or rear axle.
    By Shora in forum Shop Talk
    Last Post: 10-10-2011, 10:16 PM
  2. Replacing axle seals/bearings
    By dmjarosz in forum Shop Talk
    Last Post: 06-29-2011, 03:27 PM
  3. Axle seals went
    By MMarauder03 in forum Shop Talk
    Last Post: 10-08-2010, 08:56 AM
  4. axle seals...how hard?
    By MinnesotaMuscle in forum Steering, Suspension & Brakes
    Last Post: 06-26-2009, 11:16 PM
  5. Hp Axle bearings and seals
    By MarauderMark in forum Shop Talk
    Last Post: 09-07-2005, 04:30 PM
