Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 53
Thread: Rear Tires
  1. #16
    Oct 2011
    DC and MD Area
    I would NOT run 295's on a stock width wheel.
    https://www.tyresizecalculator.com/c...rim-size-chart
    I was debating between 295/45 or 265/35. My buddy is running 295s but he just informed me that his wheels are widened.
  2. #17
    Nov 2017
    Blue Springs Missouri
    I know some are of the opinion it’s too wide for the wheel. I’ve never encountered an issue arising from doing this and I’ve sold and mounted a lot of tires. I drive my car hard and toss it around corners like it weighs have of what it does. Never an issue. For what it’s worth.
  3. #18
    Quote Originally Posted by Mrauder83 View Post
    A 265-35 is shorter than the front tires..
  4. #19
    Oct 2011
    DC and MD Area
    Yeah I know just a set of them
  5. #20
    Lehigh Valley, PA
    Quote Originally Posted by Blakshukvw View Post
    It's not an opinion, its following the tire manufacturer's recommended specs. I also do know of someone years ago who crashed his low mile DTR from a squishy rear sidewall causing the car to sway and spin out, the kind you'd get with the boomer tire stance of putting 295's on a 8" wide wheel.
    But stance kids love to do the opposite (narrow tires on wide wheels) and you still see plenty of those cars on the road, so whatever I guess.
    2063/3214
    5377/7838
  6. #21
    Nov 2017
    Yes. You wouldn’t believe the things I’ve done to mount stretched tires. That I do believe is way more dangerous.
    a 295/45 isn’t nearly as sidewall compliant as a big bloated off road tire mud truck tire squeezed on a narrow wheel. That’s been done forever.
    As to your story about the dtr, I’ll just say there are some drivers on the road that shouldn’t be.
  7. #22
    I run 295's............ on widened wheels.
  8. #23
    Sep 2005
    APPLE VALLEY,CA
    I run the Nitto 295/45 on stock rim.
    Had a blowout last week going 85 on freeway. Held up well till I pulled over.
    No warranty on Japanese tires.
  9. #24
    Oct 2011
    DC and MD Area
    Oh wow. Ok, it seems to that a 295 tire is fine on a widened wheel or stock size it’s all on the person.
  10. #25
    I've done a ton of calcs on this, and posted here before and gotten a lot of good input. I've always kept the stock 235/50-18's on the front, but next time was considering going to either the 245/45-18 (.3" wider than OEM and .57" shorter), or to the 255/45-18's, which are .79 wider and .22" lower than OEM.
    The trouble is when going to the back, as I don't want to exceed 6% tire differential front to rear. For years I used the excellent Nitto 555 265/50-18's, which are just .2" shorter but a full .81" wider (13/16") than OEM, and they gave me a nice front to back ratio of only 4.32%, which was less than the factory 5%, but they aren't available any more.
    I'd like to consider the .4" taller and .4" wider than OEM 255/55-18's for the rear, but with the factory front that would take me to a 6.5% front to back differential. That would be a .06" height increase over the unavailable 265/50-18's, while decreasing width by .39".
    SO QUESTION: has anyone with a setup of OEM fronts to 255/55-18 rears had any issues with TC with that 6.5% front to back differential? Keep in mind that differential would increase if I ever went with one of those lower fronts, to 8.6% with the 245/45-18's, and 7.4% with the 255/45-18's, so I'd pretty much be staying with the OEM fronts if I go to 255/55-18 in the rear.
    (One consideration to go with the OEM rears; I could go to the 255/45-18 fronts and just keep the ratio under 6%, barely. Going to the 245/45-18's would take that ratio over 7%...)
    Thanks for any info as always.
  11. #26
    If you have traction control and exceed 6% dia. Difference front to back, it will activate...can run a 285-50-18 depending on front size.
    That would be nice, but not according to your statement about 6% being max, which I've heard before (OEM differential is 5%). 285/50-18 rear with the OEM 235/50-18 front is a 6.95% differential. (29.2"-27.3" = 1.9"/27.3")
    That's greater than the differential I'm asking about in the previous post between the front OEM's and rear 255/55-18's, which is 6.5%. I'd LIKE to be able to go with those .4" wider and .4" taller rears, but then I'd have to stay with the OEM fronts permanently (assuming 6.5% is OK...?) But hell, maybe you're right and with the setup you suggest you could get by with just under 7%?
  12. #27
    Member Adam runs a 285-50-18 rear..not sure of front he runs...some say 7% difference
  13. #28
    Jun 2019
    VA
    The BEST All Season, High Performance tire for a MARAUDER...STOCK Wheels
    Comes in 255/45/18 Front
    255/55/18 Rear
    https://www.tirerack.com/tires/tires...Contact+DWS+06
  14. #29
    Yeah, 7% if he has the OEM fronts. I'd be curious if that gives him any TC issues. (?)
  15. #30
    Quote Originally Posted by BackNBlack View Post
    255/55/18 Rear
    That would give a 7.4% front to back differential, which if you have TC could be a problem. I like the idea of those fronts and the OEM rears, which would give a 5.9% ratio., or those rears and the OEM fronts which would be the 6.5% I'm considering. As for the best, the Nitto's I've had have been outstanding, handling and wearing better than the BF Goodrich T/A's that cost more at the time, but I can't get the 555 rears anymore so am looking at the Motivo's.
    The question I really need answered is what's the cutoff on the differential. Some say 6%, but then are running 1 to 1.5% higher. They may not have TC though.
    (Update: I said before the ratio of front to back for our OEM tires was 5%, but it's brand specific; with Nitto Motivos it's 4.3%. I wrote down the 5% years ago with the 555's. Checking the 255/55ZR18's on the Nitto site, they work out to a 5.9 front to back ratio on the Motivos to OEM fronts, so that should be good to go.)
  1. BFG rear tires
    By 88LTDCV351 in forum Tires & Wheels
    Last Post: 01-15-2013, 08:47 PM
  2. Wanted To Buy Rear tires 255/55s
    By TiTo35 in forum Marauder Parts/Misc. Wanted
    Last Post: 02-26-2011, 01:21 AM
  3. Rear Tires
    By tomd in forum Tires & Wheels
    Last Post: 03-30-2009, 01:38 PM
  4. Help. I need rear tires.
    By Matt Johnson in forum Tires & Wheels
    Last Post: 12-09-2008, 08:53 AM
  5. Tires I need two new rear tires
    By 2004mercuryman in forum Tires & Wheels
    Last Post: 09-02-2005, 03:49 PM
