Results 1 to 5 of 5
Thread: Which oil pump?
    Longwood, FL
    Which oil pump?
    Getting ready to do timing chain guides and tensioners, figure I should replace the oil pump while I’m in there. Which pump should I get for a high mileage FI car? 161,000 miles. Seems like billet steel gears, high volume and high pressure would be desired, so Melling 10227? Or would the MMR product be better? Can we use a pump intended for the 5.4L 3-valve mod motor? I read somewhere the blocks are the same, but the dimensions of the 3-valve pump body are larger so I don’t know if they would fit (Melling 360HV or billet equivalent, I think it’s the 10341).
    2003 300B
    VIN: 677166, #6738 of 7839
    built: 2/13/03
    wrty start: 5/28/03
    84,197 on 02/21/08
    95,776 on 02/21/09
    109,301 on 02/21/10
    121,447 on 02/21/11
    125,925 on 02/26/12
    130,375 on 01/01/13
    134,831 on 2/4/14
    149,441 on 2/24/18
    Dark Blue Pearl, #128 of 327
    Feb 2017
    New Orleans, LA
    you dont want a high prea or high vol oil pump. a stock replacement is fine and has plenty capacity no problem
    billet gears are for high rpms
    you do not need a high pres or high vol oil pump and I wouldnt recommend them for anything other than a race car which has extremely loose tolerances
    decipha @ EFIDynoTuning
    The Dirty South
    I used a FRPP oil pump.
    Oct 2014
    Cunningham, Kansas
    FRPP or Melling is fine.
    I would think the main thing is to get an oil pump with solid steel gears instead of the powered metal ones.
  1. Maxflow® Fuel Pump Booster or KB boost a pump
    Last Post: 01-14-2013, 09:41 PM
  2. Oil Pump
    By Mike M in forum Shop Talk
    Last Post: 03-31-2011, 12:26 PM
  3. Bad PS Pump?? -
    By babbage in forum Shop Talk
    Last Post: 05-07-2009, 11:03 AM
  4. Replies: 47
    Last Post: 03-13-2008, 05:59 AM
  5. Bad Pump, Pump off waiting for Part...now...
    By SlkMerc in forum Shop Talk
    Last Post: 03-30-2007, 05:18 PM
