Results 1 to 5 of 5
Thread: Oil Pan
    Mar 2011
    Memphis, TN
    Oil Pan
    I am putting together a back-up motor for my stock '03 Marauder.
    This will be a REAL "toy" motor that will probably have some type of power adder. So far, I have acquired a teksid block, forged rods and pistons, FR500 cams, both "B" and "C" heads. I am also in the process of acquiring a 2003/2004 Cobra crank.
    I have searched the different forums here but could not find any real information on which oil pan most of you are using for your high HP/torque motors. Sean Hyland's book makes reference to a Canton 15-794 that has two different pickups (one for the Cobra Mustang and one for the GT). Therein lies the more basic question I guess....Can one use the same oil pan on our Marauder as on the Mustang?
    Thanks for any inputs and I apologize if this subject has been discussed before.
    ~BT
    You can make all the power you want, with the stock pan.
    You can also fill it with 7 quarts without the crank sitting in oil
    Lehigh Valley, PA
    Zack is right, you don't need a new oil pan.
    This is the only aftermarket pan made for panther platform cars
    https://adtr.net/product/mercury-mar...minum-oil-pan/
    2063/3214
    5377/7838
    Jun 2012
    Grand Rapids
    If you need a stock pan, I have a few.
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Mar 2011
    Memphis, TN
    THANKS for the inputs, guys!
    I think I will go with a stock pan...PM sent to Curless.
    Thanks again!
    BT
