Results 1 to 15 of 25
Thread: NEED replacement key fob/advice how to replace
    Jun 2019
    VA
    Since the “SEARCH” function here stinks...
    any help or advice to replace would be appreciated. I see TONs that look like the originals on eBay, but don’t want to buy something that won’t work. Also, must I go to Ford dealer to program?
    Thanks in advance!
    Oct 2014
    Charlotte, NC
    I bought one off of eBay that was included with a Mercury key blank. Ended up buying a key fob from the local dealer for $55 and having both new key fob and eBay key blank programmed to my car for another $50. Local Ace hardware cut the key to match.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    I bought a couple generic ones off amazon, programming is easy, starting with the key off, turn it on/off 8 times, ending in the run position, the locks will lock/unlock, press the lock button on your new fob, locks will lock, turn the key off and your done.
    Trilogy # 192 / T.S. 0012
    Jun 2019
    VA
    Thanks guys for the replies. I’ll give it a try and see how I do.
    Oct 2014
    Cunningham, Kansas
    I beleive they are still available at your local Ford dealer. The E-bay FOBS seem to be somewhat hit or miss.
    Jul 2018
    Peoria, Illinois
    BackNBlack,
    Not sure that this is your problem as I'm thinking you're after a complete FOB that would need programming, but I'll throw this out there: A few months ago, the key-ring attachment point broke. A few weeks later I found a replacement black-colored fob clam-shell at the counter of Advanced Auto that looked almost identical except for hollowed out pictograms. (See image) It was easy to switch out the internals from one FOB to the new one. Now I use that as my primary FOB and keep my 1 remaining original for safe keeping. For what it's worth, if memory serves, I believe they also offered complete FOBs ready for programming. The whole solution was very affordable. I think it cost me less than $10.
    Black5Projects
    2003 Mercury Marauder, black, 95XXX miles
    2012 Ford F150 Roush Raptor
    Jun 2019
    VA
    Quote Originally Posted by Black5Projects View Post
    BackNBlack,
    Black5Projects
    Quote Originally Posted by Fastbob View Post
    Thanks...that actually IS/WAS the issue. I ordered a couple off ebay...we'll see if I "hit" or "miss'
    Thanks for the answers.
    https://www.amazon.com/Keyless-Linco...rcury+Marauder
    $15 on Amazon
    Nov 2006
    Union City, CA
    I bought my extra Mercury key blank many years ago on ebay. Had finally got around to trying to get it cut and IPATs programmed a few months ago. Osh (before they went out of business) wouldn't cut it because it didn't fit in their machine and I didn't want to buy one of their generic programmable keys. Ended up just going to a stealership during a regular mainenance visit, and they cut and programmed it on the cheap. Works good.
    1988 LTD Crown Victoria S
    Nov 2006
    Union City, CA
    I did get a generic fob. I'll try this method to see if it works.
    Jun 2019
    VA
    I received my FOB(s) from an eBay purchase. I have tried EVERYTHING to program them with NO SUCCESS. I can get the locks to “Cycle” with 4 quick Off to RUN CLICKS OF THE KEY ENDING ON RUN. I PUSH ONE OF THE BUTTONS ON THE FOB(s) *i got 4 of them...but NO LUCK GETTING THEM TO PROGRAM!
    i opened one with a coin to check for battery...in there, no problem, but this is getting infuriating!
    any thoughts other than “you’re DOING it WRONG”! TWSS
    The only thing that comes to mind is that 4 remotes are programmed into the system and need removed first. I know I can remove them with IDS, I don’t believe you can program over them if they are already in the DDM.
    Jun 2019
    VA
    Thanks for the reply. I understand the “4 remote limit”. The ONLY key fobs the car has are the two originals. I only have my hands on one of the original 2 (spare key, Valet key & extra FOB packed in a box “somewhere”).
    I purchased 2 sets of 2 FOBS =4 from what seemed like a reputable eBay seller who has sold 500+ FOBs before, with 100% rating...total price $16.XX shipped. The car “cycles” on the 4th key from OFF to ON...leaving in ON, I push one of the button on one of the NEW FOBs...and NOTHING!
    Needless to say, after a couple dozen tries, getting REAL frustrating. Probably just need to ask someone else, who’s not pissed off about it, do it at this point...as I DON’T seem to “have the touch”
    oh...and ORIGINAL FOB from 2002 STILL WORKS, so it didn’t “de-program”...
    *steaming MAD*
    Quote Originally Posted by BackNBlack View Post
    *steaming MAD*
    Do you have Forscan software?
    Jun 2019
    VA
    nope...I’m circumcised...
    *EL OH EL...i have no idea what that is...so no...don’t have it
  1. Need advice with replacement tires.
    By LoneWolf in forum Tires & Wheels
    Last Post: 09-04-2013, 02:16 PM
  2. Fix or replace them?
    By LilCop2002 in forum Tires & Wheels
    Last Post: 03-27-2011, 02:43 PM
  3. Replacement Fuel Pump Advice
    By joecool240 in forum Shop Talk
    Last Post: 04-07-2010, 06:51 PM
  4. What do I need to replace?
    By Motorhead350 in forum The Lounge
    Last Post: 03-25-2008, 08:17 PM
  5. How to replace.....
    By CRUZTAKER in forum Shop Talk
    Last Post: 06-06-2003, 04:38 PM
