Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Current options for new rack and pinion?
  1. #16
    Sep 2008
    B'lo, NY
    Ha that's where I got the numbers from. In fact, I think YOU gave me that document some years ago!
    Do you happen to have that same doc for the crown vic? Would love to see if there's any number differences.
    To do list:
  2. #17
    Timbuk3, MI
    Post
    dmjarosz ...Do you happen to have that same doc for the crown vic? Would love to see if there's any number differences.
    The part number for the Crown Victorias is the same as that for the Grand Marquis - 3W1Z-3504-FAPRM
    As for the same doc for the crown vic ...
    Documents CROWN Victoria ««« -click-
    » Service:
  3. #18
    May 2004
    (The other West Coast) Wyoming Michigan
    ΓρεεκΓοδ
  4. #19
    Sep 2008
    B'lo, NY
    Stated in the info section:
    Total Turns Lock To Lock 3
    Even though it will physically fit and will probably function properly, its not the correct Marauder lock-to-lock turns of 2.81
    I'm hunting for a true Marauder replacement, though that might be a pipe dream these days...
    To do list:
  5. #20
    May 2004
    [QUOTE Stated in the info section:
    I'm hunting for a true Marauder replacement, though that might be a pipe dream these days...[/QUOTE]
    Pipe dream indeed! The rack & pinion assembly application is for ONLY a 2003 or 2004 Marauder, and 2.81 is rounded off to 3. Do you seriously think you could even tell the .19 difference between the stated specs (IF the numbers were not rounded off)? On a Marauder 15" steering wheel, that is about a 2" difference on the outside diameter of the steering wheel.
    ΓρεεκΓοδ
  6. #21
    Wisconsin
    Quote Originally Posted by GreekGod View Post
    Pipe dream indeed! The rack & pinion assembly application is for ONLY a 2003 or 2004 Marauder, and 2.81 is rounded off to 3. Do you seriously think you could even tell the .19 difference between the stated specs (IF the numbers were not rounded off)? On a Marauder 15" steering wheel, that is about a 2" difference on the outside diameter of the steering wheel.[/QUOTE]
    Actually yes he could.
    It isn't about the lock to lock numbers, they just identify a sports steering ratio from standard.
    Putting the 3.0 in a Marauder would be liker putting a Caprice steering box in a Camaro, or a Lincoln steering box in a Mustang.
    It's all about steering response time for handling.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
  7. #22
    May 2004
    It's all about steering response time for handling.[/QUOTE]
    So, you know for a fact that they did not round off 2.81 to 3? You are saying that they are not Marauder spec. r&p's? Are you saying they are not variable ratio r&p's? He "made it" about "lock to lock" numbers. Are you aware that the Marauder has a variable "sports" steering ratio?
    ΓρεεκΓοδ
  8. #23
    Wisconsin
    So, you know for a fact that they did not round off 2.81 to 3? You are saying that they are not Marauder spec. r&p's? Are you saying they are not variable ratio r&p's? He "made it" about "lock to lock" numbers. Are you aware that the Marauder has a variable "sports" steering ratio?[/QUOTE]
    No, I've never researched i. but when it comes to auto parts they would never round off a number combined with FOMOCO having different part numbers for them would lead me to believe they are different. I know driving my MM the steering is much more responsive than a GM.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    JL 6.5 SubWoofer
    Mo's Dyno Tune
  9. #24
    The Marauder R&P is different from the CV/GM part. I ordered one at O'Reilley and it works perfect. BTW, mine wasn't worn out, the housing broke when the car slipped off a jack. Yes, I was improperly jacking the car at the crossmember and the jack was too close to the edge. Slipped off and PS fluid went everywhere. They accepted the broken one for the core charge, too.
  10. #25
    Sep 2008
    B'lo, NY
    I'm positive they didn't round off. While I don't know exactly, mine is between 2-3/4 and 2-7/8 turns. If you put a small piece of tape at 12-o'clock while at one extreme, you can easily differentiate in 1/8 turn increments. I did the same in two friends' GM and CV and both are exactly 3 turns.
    Ha, not meaning to muddy the waters even more but I found a "limousine package" application for a steering rack but could not find any specifics on what Ford included in that package. My gut hunch would be different variable assist configuration and possibly longer rack travel to help with turning radius on a longer vehicle? I really have no clue but hey, there are no bad ideas in brainstorming!
    I believe the "variable sports steering ratio" you are referring to is the EVO (electronic variable orifice) that, when commanded open, allows steering fluid to bypass the steering gear, providing the driver with lower steering assist as highway speeds. I thiiink the valve itself is also specific to the Marauder as well and I know its not sold as a separate part. God forbid mine ever goes bad and i have to custom manufacture custom one...
    I've also yet to hear back from Rack Doctor and I will try again. I told them about the different ratios and EVO valving and asked if they will rebuild my own rack so i know I'm getting the same internals back.
    To do list:
  11. #26
    Lehigh Valley, PA
    Quote Originally Posted by dmjarosz View Post
    Long long ago I had read a post (probably on MotorCityMarauders) about Steve Babcock talking about using a "limo" steering rack (he may have even said gear if this was on the original prototype) to test a quicker ratio steering setup, but decided not to go with it because they were afraid of old people over-inputting and spinning out.
    I was always under the assumption the only difference between a CV and MM rack was the level of variable assist. If you end up proving otherwise that the Marauder does indeed have a slightly quicker (although IMO still not quite quick enough) rack ratio, that'd be quite a find so many years after these cars were made.
    2063/3214
    5377/7838
  12. #27
    Sep 2005
    APPLE VALLEY,CA
    I purchase a rebuilt unit for my Black from a guy in Florida off of car-parts.com with lifetime warranty.
    Used his rack and replaced everything else with the stuff from my car.
    Still no problem after 2 years.
  13. #28
    Jun 2006
    Central New Jersey
    Thanks! I definitely checked out that site. I emailed them with a few questions including asking about the marauder-specific EVO valve and the 2.81 lock to lock ratio. I Will share answer when they arrive.
    I was wondering how this has worked out for you or anyone else. The rack and pinion is now leaking on my car.
    Build Date 3/19/04
    Adopted on 10/19/07
    Seq#2102 of 3214
    #681 of 997 SBs
    #154 of 336 SBs with the moonroof
    Thanks Brian
    Member of The 100K Club 11/20/11
    Options-
    moonroof-heated seats-6-disc changer-trunk organizer-rear spoiler-mercury all weather mats
    Mods-Extras-Bling-
    Action Automotive-SS Inserts
    Auto Meter 4327 Oil Pressure Gauge
    Badgeless Grille(Thanks 03 Merc)
    Big Mike's Performance-"Sto n Sho" License Plate Holder
    Dead Pedal(Thanks lji372)
    Curless's Pedal Gear Repair
    Cruzer's-Arm Rest
    EATC Ungrade(Thanks JACook)
    Escape/Audiophile Radio Upgrade(Thanks shodude)
    Ford Racing M-7195-AOD Aluminum Trans Pan
    Innovative Interceptors-God's Head Valve Stem Covers
    J-Mod Valve Body
    K&N Performance Intake Kit{CAI}
    LCM Upgrade(Thanks Fastblackmerc)
    Marty-O Fender Badges, Tune & 4:10s
    Panther Lights HID Headlights
    Pro-gard Skid Plate
    Rear Cooling Head Mod
    Visteon Sirius Satellite Radio Setup(Thanks RoyLita)
    Weather Tech-Side Window Deflectors
  14. #29
    Sep 2005
    APPLE VALLEY,CA
    Still working perfectly!
  15. #30
    Sep 2005
    APPLE VALLEY,CA
    I was told the electrical connection is different in the Marauder then the GM or CV.
  1. Replies: 7
    Last Post: 01-05-2023, 07:57 PM
  2. Rack and Pinion leaking
    By dankwun in forum Shop Talk
    Last Post: 12-14-2012, 11:26 AM
  3. rack and pinion
    By jvillerauder in forum Shop Talk
    Last Post: 04-13-2009, 01:54 PM
  4. Rack & Pinion DOA
    By N40GL in forum Shop Talk
    Last Post: 02-15-2008, 07:44 PM
  5. Replies: 4
    Last Post: 10-07-2003, 06:59 AM
