As some of you may know. I am in the process of building a backup motor for my 2003 Marauder. While heavy into Ford pushrod motors, the Mod motor is relatively new for me as it come to modifying one. As a result, I am using this site extensively as I gather parts and information.
I have a '99 Teksid block and 2003 SVT Cobra crank and heads. I have come to understand there are possibly three different timng chain covers for the 4.6 DOHC motor and am trying to determine which timing cover I should use for this initial NA (I made go blown later) motor.
I am sure some of you have made or built a similar motor and I would appreciate any insights as to which timing cover was used. I am also interested in purchasing the timing cover.
Thanks!
~BT
