Results 1 to 12 of 12
Thread: Project Rolling Thunder
    Oct 2014
    Charlotte, NC
    Smile Project Rolling Thunder
    Marauder motor into a Mazda B2500 (Ranger). I've found 4 installments on Youtube, two dated 2013 and two dated 2020. Finished product has an Eaton blower.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    Oct 2014
    Charlotte, NC
    These episodes may be posted out of order - my apologies.
    Current Garage:
    William W. Purkey
    Oct 2014
    Charlotte, NC
    Current Garage:
    William W. Purkey
    Oct 2014
    Charlotte, NC
    The last episode on Youtube. I suspect there are more episodes of Project Rolling Thunder on the Power Nation website.
    Current Garage:
    William W. Purkey
    Nov 2006
    Union City, CA
    I wondered whatever happened to this. Seem to recall it from 2013 or so.
    1988 LTD Crown Victoria S
    First off, a junkyard Marauder engine is not the cheapest option for a 4 valve mod swap....they're rather rare (and sought after by guys like us).
    Secondly, why would you use a heavy, HUGE, and quite honestly, underpowered 4.6 modular ?!?
    A junkyard F150 Coyote 5.0 engine is clearly the way to go....you start off with 90 more HP and 90 more Lb Ft of Torque...with zero mods!
    Lehigh Valley, PA
    This segment originally aired in March of 2010, the Coyote simply didn't exist (for consumers) back then
    2063/3214
    5377/7838
    My bad,
    I didn't watch all the videos of the build and didn't realize how old it was.
    Still a waste of a Marauder engine....could've used a wrecked Aviator.
    Lehigh Valley, PA
    My bad,
    They ended up throwing it all out and swapped to an aluminator + 2.3 whipple when they did the "stage 2" build anyways
    2063/3214
    5377/7838
    Jeez.....figures!
    Those dipshits couldn't build a pile of $h*t in a elephant incontinence ward!
    Lots of TV money, but a shortage of brains and know-how.
    Oct 2014
    Charlotte, NC
    Current Garage:
    William W. Purkey
    Oct 2014
    Charlotte, NC
    Another lost episode. This is where they made the decision to pull the original Marauder motor due to a connecting rod issue (theft recovery).
    Current Garage:
    William W. Purkey
  1. Anyone rolling 20's?
    By feudingscooter in forum Tires & Wheels
    Last Post: 06-03-2013, 12:28 PM
  2. Project Rolling Thunder (MM block swap onto mini truck)
    By tdotcv in forum Community Discussion
    Last Post: 06-19-2012, 04:37 AM
  3. Where's Rolling Thunder?????
    By Pat in forum North Texas Marauders
    Last Post: 05-30-2009, 07:41 AM
  4. Rolling Thunder, Ya got me!
    By CRZYBIKER in forum North Texas Marauders
    Last Post: 09-04-2007, 07:47 PM
  5. I must look like a rolling commercial
    By Blackmobile in forum The Lounge
    Last Post: 01-10-2007, 07:10 AM
