Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 75
Thread: 6R80 Swap
  1. #46
    Man. Makes me want that trans in my car. With 4.10 gears it looked like it was 40 ish mph when it did the 1-2 shift...
    my 2011 50 Mustang with the six speed automatic and factory 319 gears . It would shift at 40mph 80mph and 120mph
    but that was at 7,000 rpm. Any idea what it shift at mph wise now?
  2. #47
    Apr 2010
    KSA
    Really, this makes me very interested in this swap.
    - Do you have part no. or webstore for the 1 inch driveshaft spacer as I searched but didn't get same as above.
    - The original marauder flexplate will fit with 6R80. Right?
    Sent from my SM-N950F using Tapatalk
  3. #48
    Jan 2016
    South NJ
    Quote Originally Posted by Talal DTR MM View Post
    https://youtu.be/d6clHnfo8n4
    Check out his website in the description. Super friendly and helpful guy. His spacer came with arp hardware as well. Very nice piece.
    Yes, original flexplate works fine.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    14.33 @ 96.82 with OLD engine
    6R80 swap in progress
    1968 Chevelle
    NA/Pump Gas 10.4 @ 128 mph
    416/4L85E LSA Supercharged build underway
  4. #49
    Jan 2016
    South NJ
    I honestly dont remember, but it is all programmable through the box. It's just plots on an X Y graph and you can fully customize every aspect about the transmission. I love it.
    The only thing I have left to do with it is get my push button shifting working. This allows you to manually upshift or downshift using your cruise control buttons on your steering wheel. And yes, cruise control is still retained.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  5. #50
    Jan 2016
    South NJ
    Just an update, I put a new radiator in. I cut out the old transmission cooler for more airflow across the radiator (since I'm installing the heat exchanger soon). I left the brackets and the ps pump cooler in place.
    I replaced the drivers side fender since it was rotting away, and it also looks like I will end up with belt size part number k080505 for the supercharger.
    The eaton pulley definitely hits my hood insulation, so I will likely be cutting that out and maybe putting a sticker or a stencil of the mercury head on there. Something tasteful and minimal.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  6. #51
    Jan 2016
    South NJ
    Anyone have a recommendation on a replacement hood insulation material that isnt 150 bucks? Prefer for it to be black / neutral color.
    I saw some from dei, anyone use that stuff?
    Also, here are a couple updates from today. I have the intercooler pump mounted and wired. Battery tray is in, and I made brackets for the fuse box, which is in loosely until i figure out the final routing of the intake tube.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  7. #52
    Wait til you see me what shipping is for hood pad. It's not rolled up..it's in a box almost size if hood. Get it from the dealer, they will get it with their stock order do no shipping $. Or spray paint yours satin black, it cleans it up decent, or go to pick n pull and grab one from a Marquis or vic
  8. #53
    Jan 2016
    South NJ
    Haha screw that. Part of the reason is the sag, it contacts the supercharger pulley. I was looking for something stick on like dynamat, with a focus on heat primarily, instead of sound.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  9. #54
    Cut out a square hole where pulley rubs and live edges with rubber hose split down side to make a border. Somewhere there is a pic of that.
  10. #55
    Marauder hood pad was thinner than CV, Marquis as theirs are for more sound deadening. I had my Marauder pad wrapped by Car Motorsports. But I also have 2.8 pulley so barely touches it. Ruined a brand new CV one as they are thicker, fluffy like.
  11. #56
    Jan 2016
    South NJ
    Anybody ever run into an issue where the fan controller contacts the body of the alternator?
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  12. #57
    Apr 2015
    Prescott Arizona
    I relocated my fan module 180° of its stock location because of the same issue. I suggest remounting it and running new wiring to it from the connector. If I can grab a picture of mine on Friday I’ll post it.
    As for the 6r80 swap. I’m currently swapping mine. I pulled my motor out for a few new things/ upgrades to the whipple supercharger unit. Figured I’d ditch the 4r75w and do the 6r80 like you did. I’ll be very curious as to how it handles my 4.10 gears and the whipple/ comp cams.
    Unfortunately I’m going slow and taking my time with it at the moment so it’ll probably be next year before I’m all said and done.
    btw anyone looking for the 1” spacer that company is currently out of stock and won’t have any for another 2 months or so. I’m at a stand still with that last piece.
  13. #58
    Jan 2016
    South NJ
    Quote Originally Posted by Rafael View Post
    Thanks man. A picture would be nice for sure.
    Yes you will likely be dropping some gear, depending on your usage. I expect to be dropping back to 3.55s at some point honestly. I do a decent amount of highway driving , but we'll see what acceleration is like.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  14. #59
    May 2020
    Georgia
    This is really cool. I'd like to something like this someday, get rid of that 4 speed slushbox and stick in an auto with more forward speeds.
    2003 300B Mercury Marauder
    Built 01/22/03
    Purchased 01/29/20
    68,xxx miles
    July 12, 2023 - 68,203 Miles - RIP original engine
    October 31, 2023 - Rebuilt engine installed
    Modifications/Stuff I have done on the car:
    Engine:
    rebuilt stock; slightly overbore. Original 68k mile heads, new OEM Ford performance timing kit, Terminator Cobra Oil Pump, Billet Steel oil pump gears, ARP head studs, main cap studs, and side bolts. The latter ARP stuff for future endeavors.
    Transmission:
    Thor 2800-3000 Stall Converter
    Suspension:
    ADTR Front + Rear Sway Bars
    Metco Billet Watts Link
    Metco Billet Rear Control Arms
    Cosmetic:
    1998-2003 Amber tail lamp conversion - Painted and smoked to near-OEM spec.
    HID Projector Headlamp Retrofit
    OEM Mercury Mountaineer Hitch Cover
    Front in-channel rain guards
    Other Stuff:
    4-pin trailer harness
    Class III Tow Hitch
    Cadillac 4-note horns
    Hayden 679 Transmission Cooler
    Obligatory Marty Tune
  15. #60
    Jan 2016
    South NJ
    Current status for those following the eaton swap portion.
    2003 Marauder 300A
    #2928 of 7838
    Build date: 8/6/02
    Ship date: 5/28/03
    1968 Chevelle
  1. Replies: 841
    Last Post: 01-31-2021, 11:54 PM
  2. 5.0L Coyote - 6R80 2003 Marauder
    By Invective in forum The Lounge
    Last Post: 04-17-2020, 11:06 AM
  3. 2010 Grand Marquis Coyote/6R80 With A Dash Of Whipple
    By bob@84auto in forum Power Adders
    Last Post: 01-03-2020, 08:27 PM
  4. LCM swap.
    By Marauder-Mike in forum Shop Talk
    Last Post: 11-26-2010, 04:03 PM
  5. Cam swap
    By Big House in forum Shop Talk
    Last Post: 11-09-2006, 08:54 PM
