Results 1 to 6 of 6
Thread: Who does what for gauges?
    Sep 2008
    B'lo, NY
    I'm finally getting back to my Eaton swap completion after a few year hiatus. Next up is mounting the gauges. So far, I have real oil pressure and trans temp in the center console and I have not removed the cigarette lighter.
    I need to mount boost and wideband O2 gauges somewhere. I have a 3-gauge pod for the A pillar that I purchased a long time ago so if I go that route, I'll have and empty slot that I either have to plug or fill with another gauge.
    What does/like what kinda setup? I've been contemplating the following and would like some advice since moving them after install seems like a hassle.
    1) Install in A-pillar pod and leave one slot empty or fill with another gauge. Suggestions on what to fill with?
    2) Ditch the A-pillar pod altogether and mount on steering column. Not sure of mounting options or how in-the-way it will be.
    3) Ditch the A-pillar pod altogether and drill out the center console cigarette lighter to add boost gauge. I would then ditch the trans temp gauge and replace with wideband O2. I have a trans cooler installed and have been constantly monitoring the trans temp and it almost never gets above, 170°F and have never seen it over 185° even after hard driving in the hottest of weather. Because of this, I no longer consider the trans temp gauge necessary. What about oil pressure? That seems super important but by the time you notice an issue on the gauge, its probably too late anyways.
    Ugh, first world problems.
    I'm also not 100% I'm posting in the correct forum.
    To do list:
    Apr 2010
    South Florida
    Here's mine, I will replace My water temp with a Fuel Pressure soon.
    Wisconsin
    Wanted mine in front of my eyes at all times. Putting less important gauges on the A-pillar.
    WLB
    #2912 of 7093
    Conceived 8/6/2002
    Delivered 9/19/2002
    Adopted 8/10/2011
    Pioneer 6x8 Front
    Legacy 600w 6x9 Rears
    JL 6.5 SubWoofer
    DR Deep Aluminum Trans Pan
    Mo's Dyno Tune
    Gorilla Nuts - The System
    Apr 2010
    South Florida
    I had mine there originally but the lights blinking and lighting up in Your face all the time gets annoying.
    Sep 2015
    Mississippi
    Yea I spray painted mine with some of the tail light tint spray and worked perfectly.
    Sep 2008
    B'lo, NY
    So fill up all three spots on the A pillar, drill out the extra spot on the console, AND mount the SCT... Got it!
    To do list:
  1. For Sale gauges
    By Triple Threat in forum Marauder-specific Parts for Sale
    Last Post: 02-04-2011, 10:06 AM
  2. Gauges
    By DOOM in forum Community Discussion
    Last Post: 04-25-2008, 08:59 PM
  3. more gauges
    By shakes_26 in forum Shop Talk
    Last Post: 07-30-2005, 04:28 AM
  4. Help on gauges!
    By YRUSLO in forum Shop Talk
    Last Post: 06-05-2005, 09:17 PM
  5. More Gauges
    By FordNut in forum Shop Talk
    Last Post: 05-26-2005, 08:57 AM
