Results 1 to 7 of 7
Thread: Too much oil?
    Sep 2006
    Deer Park, Long Island
    Too much oil?
    I think I mistakenly over filled my oil by half a quart during my last oil change and the oil level is a little above the MAX line on the dip stick. Should I be concerned and try to drain half a quart of oil somehow, or is half a quart within the tolerance of what it can handle?
    Apr 2010
    South Florida
    Too much oil?
    Drain the filter. Or put a new filter on and start it. See if it dropped down. I always put 6-6.5 quarts. I have a catch can installed so a little more is ok for Me.
    Oct 2003
    Beaufort, SC
    You should be fine like it is......a quart over FULL is not even a problem...as I recall Zack proved it!!
    Mar 2014
    Tampa, FL
    You should be just fine. A couple of members have attested to this. Half a quart should be within tolerance and should not be enough to create any frothy oil or crankcase pressure issues.
    2003 Black 300A
    Adopted: 4/26/14
    Mods:
    Mo's Tune - K&N CAI - 4.10 FOMOCO gears - Reische 170* T-stat - NGK TR6 Plugs - Flowmaster 40s - MuscleMerc's 3" Fuel Filter Mod - Addco Front and Rear Sway Bars - TCE SS Brake Lines - Cooper RS3-G1 - Factory Spoiler - SS Bumper Inserts
    Sep 2006
    Thanks. I figured it was within tolerance, I just wanted to be sure.
    Stock pan can hold 7 quarts before it goes over the top. And it’s still not hitting the crankshaft
    Sep 2008
    B'lo, NY
    Ive always filled with 7 qts, mainly because I don't like having the half quart sit around then I wonder if I have a half quart sitting around when I'm out buying oil. Plus I think this question was answered years ago?
    To do list:
