Results 1 to 14 of 14
Thread: Advice Requested: Ridetech HQ Front Coil Over System
    Jul 2014
    NY
    Looking for advice. About two months ago my OEM right front coilover cracked and broke. The OEM ones are now obsolete and the dealer was only able to get the Grand Marquis option which make the car sit too high in the front. I honestly can't stand it and miss the rake and stance of how the car used to look. I am considering the RideTech HQ Front Coilover System. For those who installed the RideTech, did you experience any issues with installation or with adjusting the height to get the OEM rake once again? Thank you in advance.
    People that have them don't set them to factory ride height, I didn't install mine, MO's did, but it doesn't get much straight forward. It is going to lower the car. How much will depend on your setting. Buy the spanner wrench as it doesn't come with. Plan in camber bolts too.
    I just did my 06 gmq and it's pretty straightforward. You will need the camber kit. Initial drop is like 1.5-2" over factory. My setup came with the spanner. I went close to 3" drop on mine
    Sent from my moto g(7) play using Tapatalk
    Jun 2019
    VA
    I LOVE how mine sits...with the ORIGINAL set of QA1 Coilovers from Naake
    http://www.naake.com/store/specials/mercury-marauder
    Lehigh Valley, PA
    I have the Ridetechs and its one of the best mods I've ever done to my car. I don't know if you can get it back to a stock ride height (which IIRC is 28.5" give or take build quality variances), maybe if you had the coil adjustment at the very top. My car is set at 27" which is a 1.5" drop over stock, you could at the very least go up to 27.5" which would be a 1" drop.
    They will ride so much nicer and handle so much better than the factory springs. I just can't speak to how they'll handle salt brine after some time, I imagine they'll start getting crusty.
    Send Chris @ adtr.net an email or message on facebook if you have any questions, he re-tuned my shock valving during drag week and really got everything dialed in for me. He is also the only guy you can get the adjustable rear shocks from which I'd suggest doing, it brought my rear end under control after lowering it a bit.
    Quote Originally Posted by BackNBlack View Post
    A lot of people who went with the Naake setup experienced blown out shocks back in the day, they were undersized for this application and simply do not last.
    2063/3214
    5377/7838
    Jul 2014
    NY
    Are these the tools and kit I would need?
    7888-110 - Spanner Wrench / Thrust Washer Kit
    http://www.naake.com/store/7888-110-..._name=7888-110
    and
    SPC Camber Kit Part # 87365
    https://www.tirerack.com/suspension/...3&autoModClar=
    Apparently, ridetech supplies spanner wrench, mine was done on 2017so maybe it didn't make the package.
    Jun 2019
    VA
    Funny...mine have been on since 2004...
    must be driver error.
    Lehigh Valley, PA
    Chris included a wrench with my kit, IIRC if you order from ridetech direct the wrench is an add-on but I could be wrong
    2063/3214
    5377/7838
    I bought direct from Ridetech so maybe that why.
    Lehigh Valley, PA
    This is the tool Chris includes, works fine for me
    https://www.summitracing.com/parts/m...BoCNqUQAvD_BwE
    2063/3214
    5377/7838
    Jul 2014
    NY
    Quote Originally Posted by tobiasg1995 View Post
    How much work was it dealing with the camber kit? Some people mentioned "grinding" or doing some other modification during the installation process of the RideTechs?
    Lehigh Valley, PA
    you have to slot the crossmember to allow for the camber bolts to do their job. SPC has an install video on their website
    https://www.spcalignment.com/index.p...tion&pid=87365
    This is independent of the ridetechs, its required if you drop the car over 1". I had to do this back when I did my eaton detroit 1.5" drop springs, my black car which dropped 1" after I cut coils did not require the SPC bolts.
    2063/3214
    5377/7838
    Not bad at all. You can use a die grinder or Dremel with a carbide bit. When you have the alignment done you can have them do it since it'll be on the rack anyway.
  1. Re: Advice Requested / LED Bulb Upgrade
    By Ambitious1 in forum The Lounge
    Last Post: 03-27-2020, 12:43 PM
  2. Re: Advice Requested / Brake Calipers
    By Ambitious1 in forum Steering, Suspension & Brakes
    Last Post: 02-15-2020, 11:01 PM
  3. Re: Advice Requested / Front Struts & Springs
    Last Post: 01-25-2020, 11:44 AM
  4. Replies: 15
    Last Post: 10-30-2019, 10:04 AM
  5. Re: Best Engine Oil / Advice Requested
    By Ambitious1 in forum Shop Talk
    Last Post: 08-07-2019, 03:42 AM
