Results 1 to 5 of 5
Thread: Marauder cranks but won't start
    Sep 2005
    APPLE VALLEY,CA
    I Haven't driven my silver in a month. The battery was dead, so I charged it. Went out to start it, it cranked but would not turn over.
    Killed the battery again. So I looked here and found this post: D*** Fuel Pump Troubleshooting Guide.
    I had already checked the switch in the trunk, and the PATS was not flashing while cranking. I pulled up my black Marauder and set up the jumper cables. Then I did step 2: Fuel Pump Fuse. This is a 20A fuse in position 5 in the power distribution box in the engine compartment right behind the battery. In the past I have seen a fuse not work even though it didn't look blown so I swapped the #5 fuse with the 20A fuse
    in position #2. This fuse is for one of the power points so it won't keep the engine from starting if we wind up moving around a bad fuse. I cranked the engine, and it strarted right up. Thanks for the help.
    Jun 2008
    Waukesha, WI
    Glad you were able to figure it out!
    Feb 2006
    Rosemount, MN
    I had a similar problem about a year ago and it turned out to be the FPDM Fuel Pump Driver Module.
    Cranked = Turned over
    Wouldn’t start, fire, run, ETC.
    J/K Glad you got it!
    Feb 2017
    New Orleans, LA
    the turn over thing threw me too
    in my experiences if it popped the fuel pump fuse more than likely the contacts at the fuel pump plug are corroded.
    We had a NOPD marauder at the shop last year for some work and the next morning it wouldnt fire off. Wasnt getting any fuel. Cleaned the connector for the fuel pump and it fired right up.
    decipha @ EFIDynoTuning
  1. Help! Engine cranks but wont start
    By GetMeMyStogie in forum Shop Talk
    Last Post: 04-02-2015, 05:46 AM
  2. Car won't start. Cranks but won't fire.
    By Steve in forum Shop Talk
    Last Post: 06-11-2012, 02:52 PM
  3. cranks but no start?
    By deathdealer9mm in forum Shop Talk
    Last Post: 07-21-2009, 02:56 PM
  4. Help, my Marauder won't start!
    By illwood in forum Community Discussion
    Last Post: 09-18-2007, 06:55 PM
  5. Cranks up & Cuts off / Won't Idle
    By gonzo50 in forum Community Discussion
    Last Post: 12-27-2002, 03:47 AM
