Today I took apart my dashboard because I had a blown bulb in the speedo cluster. Since I had it apart anyway, I decided to replace all the dash cluster light bulbs with LEDs while I had it apart. I had to constantly plug test and unplug the cluster many times because the bulbs I got were sensitive to voltage polarity. Eventually I got all the bulbs working but when I put it back together, my air bag light comes on. It doesn't flash any codes. It starts solid during the normal bulb test when you first start the car, then it turns off as you would expect. About 10 seconds after the light turns off, it turns back on solid and stays on. Does anyone know what this means? This warning was never lit before until I opened my dash to change out the bulbs.
